EmbDev.net
Forum: DSP MATLAB SHARC BTC failure
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Markus (Guest)
Rate this post
useful
not useful
hi guys,
i am working on a student bachelor thesis where i should implement a BTC
from matlab to the SHARC ADSP-21369 EZ-Kit to edit parameters for a
simple 3-band-EQ during the board's runtime.
i have now a class in matlab including the methods for accessing,
writing and reading the BTC and i have initialized the channels in
VisualDSP++ like shown in the getting started example.
now i have the following problem:
i will transmit filter coefficients für a biquad filter, so the
numerator-coefficients are 3x1 cell array, the denominator-coeffs 2x1
cell array
if i try to send these values through the BTC, the BTC memory window
shows me, that only one single coefficient of the array is edited, the
others get 0. a very interesting point is, that in the 3x1 cell array
the 2nd coefficient is edited, the first and the third get zero.
has anyone an idea how to fix this? i would need quite a quick solution,
because i have to presentate my project on monday.
here is the code ob my accessBTC.m
classdef accessBTC < handle
properties
    numChannels = [];
    isInitialized = 0; %Logical 0 or 1 to indicate if the class is instantiated to connect to the VisualDSP session
end
properties(SetAccess = private)
    channelList = {}; % Array of channel objects
end
methods
24
25
26
27
    function initialize(obj)
28
29
        a = actxserver('VisualDSP.ADspApplication');
30
31
        btcPlugin      = a.PluginList.invoke('Item','BtcManager');
32
33
        btcManager     = btcPlugin.Open;
34
35
        btcChannelList = btcManager.ChannelList(int16(0));       % Get the channel list in processor #0 (always INT16)
36
37
        obj.numChannels = btcChannelList.Count;
38
39
        disp(['Total Number of Channels: ', num2str(obj.numChannels)]);
40
41
        % Create the BTC Channel interfaces
42
43
        for i = 1: obj.numChannels
44
45
            obj.channelList{i} = btcChannelList.invoke('Item',int32(i-1));
46
47
        end
48
49
        obj.isInitialized = 1;
50
51
       % S=saveobj(obj);
52
53
   end % End of Method: INITIALIZE
54
55
56
57
    function outVal = read(obj,channelNum,width)
58
59
        % Default width is 32; other possible values: 16, 8
60
61
        % Channel num starts frm 0
62
63
        if nargin ==2
64
65
            width = 32;
66
67
        end
68
69
        widthStr = ['btcWidth',num2str(width)];
70
71
        btcChan = obj.channelList{channelNum};
72
73
        out_val = btcChan.Read(widthStr);
74
75
        outVal = cell2mat(out_val);
76
77
    end % End of Method: READ
78
79
80
81
    function write(obj, channelNum, val)
82
83
        % input val needs to be a scalar or a vector of int32 or in16 or
84
85
        % int8 values
86
87
88
89
        if nargin ~=3
90
91
            error('WRITE method for accessBTC object needs 2 inputs.')
92
93
        end
94
95
96
97
        btcChan = obj.channelList{channelNum+1};
98
99
        btcChan.Write('btcWidth32',num2cell(val));
100
101
    end %End of Method: WRITE
102
103
104
105
    function reset(obj)
106
107
        obj.numChannels = [];
108
109
        obj.isInitialized = 0;
110
111
        obj.channelList = [];
112
113
    end %End of Method: RESET
114
115
116
117
end
so if i sending for example these single arrays
    num_1 = [1.324; -1.45; 0.83]
    den_1 = [-1.45; 0.74]
i am getting in my BTC memory window as floating point
    num_1 = [0.0000000; -1.45; 0.0000000]
    den_1 = [-1.45; 0.0000000]
has anybody an idea how to fix this?
thanks a lot and best regards,
markus
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
