EmbDev.net
Forum: FPGA, VHDL & Verilog Interface AD7655 with FPGA using VHDL
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von jeorges FrenchRivera (Guest)
Rate this post
useful
not useful
Hi guys,
I'm writing A VHDL code to interface a 16-bit serial ADC to an FPGA and
I have some questions about my methodology. The ADC that I'm using is
the AD7655 from analog device.
I think the code should be very simple, but I just want to get a second
opinion so I don't end up in the wrong direction.
In fact, I'm not sure if I'm asserting and reading the data correctly.
Anyway, this is methodology:
1. Since the ADC is going to be operating in External Clock Data Read
(Previous) During Convert mode(page 22 of
http://www.analog.com/static/imported-files/data_sheets/AD7655.pdf, my
input clock needs to be 32 MHz at least. This is going to be fed into
the ADC at all time. For this reason. I followed the detailed timing in
Figure 33 in the datasheet to write my VHDL code.
2. Make a simple state machine with five state cases,ADC_STATE IS
(IDLE,START,CONV_A,CONV_B,CATCH);
3. CONV will be asserted 1 in IDLE State, the CONV is asserted 0 in
START state.
4. At the rising edge when the state is START, I make a test of BUSY
signal, if it's high the  CONV_A state can start, in which the channel A
is converted and date grabbed and placed into the register. I will stop
at CLK = 16, and at CLK = 16, the  CONV_B state can be started.
5. in CONV_B state, the channel B is converted and date grabbed and
placed into the register. I will stop at CLK = 16, and at CLK = 16, the
CATCH state can be started.
6. In the CATCH state, I will put conversion values of channel A and
channel B into another registers. Everything will now repeat by putting
the state to IDLE one.
I am in the right direction? it my first experience to write code from a
timing diagram.
In case you're interested, my code can be attached.
I'd appreciate any input you have for modification to get this thing
going.
Best regards
von jeorges F. (Company: xlue) (khal1985)
Rate this post
useful
not useful
Please i need your remarks,
Best regards
von Duke Scarring (Guest)
Rate this post
useful
not useful
What is your problem?
Do you have a testbench?
If I had your task, I would write a model for the AD7655, add a
testbench and check the behaviour of my FSM against the model.
Duke
Rate this post
useful
not useful
My problem is to to write a testbench basing on the ADC specification.
Best regards
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
