EmbDev.net
Forum: µC & Digital Electronics Query on DSP4YOU AVB switch.
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Hrusikesh P. (Company: eInfochips) (hrusikesh)
Rate this post
useful
not useful
Hi All,
We are holding your DSP4YOU 5 port AVB Switch, Powered by Marvell
Firefox series, 400MHz ARM9 core. We have our custom AVB endpoints and
using Intel OpenAVB stack to build a AVB network using DSP4YOU switch.
Now we have the following scenario
1> If we direct communicate between the endpoints without the switch, we
are able to achieve the IPG of 125uSec.
2> If we are adding the switch to the network, we are getting the IPG
around 460uSec.
3> Previously we also have tried the Intel I210 nic as endpoints, we
were getting IPG around 900-1000uSec.
Can anyone please give me some idea what could be the issue above.
Also I have the following queries,
1> Is the DSP4YOU AVB switch is compatible to all AVB Stack other than
Marvell's AVB stack.
2> I can see a serial port on this switch, If I am correct it is for
debugging purpose. Do any one have any idea how to use it for debugging
from switch point of view.
Thanks and Regards
Hrusikesh Padhy
: Moved by Admin
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
