EmbDev.net
Forum: µC & Digital Electronics AVB Controller entity ID
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von RICHARD F. (Company: Rhodes University) (richardfoss)
Rate this post
useful
not useful
If I am writing a controller application, how do I create the controller
GUID that goes into the controller entity ID field of, for example a
CONNECT_RX AVDECC command?
Thanks for any help with this!
: Edited by Admin
von Andre L. (andrelabelle)
Rate this post
useful
not useful
IEEE Std 1722.1-2013 just says it should be unique. It makes sense to
use a host interface MAC-48 and append a random number to make up 64
bits.
von Richard Foss (Guest)
Rate this post
useful
not useful
Hi Andre,
Thanks for the post and apologies for the slow reply. I had previously
received an answer from Jeff Koftinoff, which confirmed what you
indicated. I think it would be helpful to quote Jeff, and I don't think
he would mind:
"The controller is an entity. The same rules apply for the entity as
others; specifically, it needs to be unique on the network, it needs to
be prefixed by a IEEE assigned OUI  MA-L  MA-M or MA-S
Typically, people find the “Primary MAC address” of the computer that
the controller is running on.
This is a six byte value: UU:VV:WW:XX:YY:ZZ.
You then convert this to an EUI-64 in the way IEEE specifies:
UU:VV:WW:FF:FE:XX:YY:ZZ
And this would then be the controller’s Entity ID (GUID is an old term
which has different definitions)
If you need more than one controller per computer, then you would
replace the middle FF:FE with two byte values so that each controller
running on the computer would get a unique ID."
My AVDECC messages are working fine with this approach.
Regards,
Richard.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
