EmbDev.net
Forum: µC & Digital Electronics AVB propogation delay
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Mike (Guest)
Rate this post
useful
not useful
I am sending AVB audio stream 2Km on single mode fiber.
The stream originates from Biamp Tesira server via Extreme X460G2 and
terminates at the far end to Extreme X440-8p which then delivers avb
audio to Lab Gruppen Amplifier. This works fine
I remove the X440-8p and replace with single mode Gigabit Ethernet IEEE
802.3z 1000BaseTX/1000baseLX/SX converter with transition networks
L1000i-at 802.at gigabit POE injector. Tesira Server indicates Fault is
"One or more AVB streams inactive". Extreme shows msrp stream failure
code "AVB incapable egress port.
The Max peer delay setting in Tesira server is 10000ns, the propogation
time as indicated in show network clock gptp is 12855ns.
I would like to replace 8 port switch with single media converter.
Why does it work with switch but not media converter?
: Moved by Admin
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
