EmbDev.net
Forum: ARM programming with GCC/GNU tools Display registers value - ARM assembly
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Ab A. (abanel88)
Rate this post
useful
not useful
Hi there,
I was wondering If anyone can help me with this. I want to print or
write to a file and save the values of the registers running a simple
Hello world program for example. Can somebody guide me what I need to
know so I can do that? Or print to the monitor the values for example of
the R0-R4?
Any help or thoughts? Can I do this combining C or C++?
Many thanks!!
von M.K. B. (mkbit)
Rate this post
useful
not useful
You should explain what you want to achieve with your dump of the
registers. Maybe you try to achieve something else where a different
approach is more suitable.
Since you are talking about C, C++ the registers are assigned by the
compiler  so each little change in the code or compiler settings might
lead to the same data being stored in a different register. Only by
writing assembler you can control directly which register you use.
Basically you can dump the registers using a debugger by single stepping
through the assembler instructions and copy the current register value.
Keep in mind that a simple looking prinft/cout contains lots of
assembler instructions which might use your registers.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
