EmbDev.net
Forum: ARM programming with GCC/GNU tools building a cross toolchain for 68k, avr and arm
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von alexander (Guest)
Rate this post
useful
not useful
some time ago i wanted to use a current gcc for my development.
I wasn't happy with the toolchains i could download - too old compilers.
Thus i decided to compile the toolchain myself.
For this purpose, i have created a script which does all the downloading
and compiling.
The toolchain build script supports the target architectures
* m68k-elf
* avr
* arm-none-eabi.
The toolchain can be built in the following environments
* debian
* fedora
* windows (inside a msys2 shell)
For each environment there is a script to install the required packages
to build the toolchain
The script is available at https://github.com/haarer/toolchain68k
I use the self built toolchain for all my embedded development.
Since i am quite happy using a recent compiler (gcc 7.2 :) i think it
might be worth to share it with others.
Under windows and atmel studio it is also very simple to integrate the
toolchain into atmel studio. It works also together with eclipse.
There are also some examples and makefiles in the repository for 68k and
arduino development.
Have fun!
Alexander
http://haarer.github.io
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
