EmbDev.net
Forum: DSP What is the effect of reducing nfft less than the signal length
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Usman A. (Company: LUMS) (usmanashraf678)
Rate this post
useful
not useful
Dear members,
I am analyzing a signal in matlab by taking its fft. The singal has 200
samples and I am currently taking nfft = 256. I understand that this
would result in zero padding. Now, I want to try to reduce the nfft to
128, 64 etc. I wanted to ask what should I expect to happen with the
fft.
Matlab says
for Y = fft(X,n)
If X is a vector and the length of X is greater than n, then X is
truncated to length n. What would this actually result in? Can anyone
explain, please?
Thanks in advance.
von Andreas S. (andreas) (Admin)
Rate this post
useful
not useful
You will get a reduced frequency resolution, and, depending on your
input vector, windowing artifacts (you can consider truncation as
equivalent to applying a rectangular window).
von Martin B. (Guest)
Rate this post
useful
not useful
You may also use Nfft = 200
I think in matlab you can use any number Nfft which is a factor of
2,3,5.
It is not neccesary to use Nfft = 2^n, You may also use
Nfft=200=2*2*2*5*5
Most fft librraries are able to use these numbers of Nfft (fftw, kissFFT
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
