EmbDev.net
Forum: µC & Digital Electronics Link External RAM Arduino Mega 2560 (with Arduino IDE?)
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Jonas B. (dr_j0nes)
Rate this post
useful
not useful
Hey Volks!
I have expanded the RAM from my Arduino Mega 2560 from 8 to 40kb with an
32kb SRAM.
I have set the XMEM Registers in the program and edited the boards.txt
from the arduino ide so that the max memory is now 40kb.
I want to use the arduino ide and as a test I declared an int array with
the size of 16000. I put the index as the data for each array element.
In the last step I iterate with a for loop thru the array and send the
data of the elements via serial to the arduino ide terminal.
Nearly all the results in the teminal look like expexted but around the
adresses of the end of the internal RAM the data in the array just give
out random numbers.
I think its because i just expanded the memory size in the Arduino
boards.txt from 8 to 40kb. It seems that the mcu reserves the stack as
normal variable space.
Does somebody get what i did wrong or how i can link the external memory
in the arduino ide properly?
Thank you for your time!! :)
: Edited by User
von Carl D. (Guest)
Rate this post
useful
not useful
One description of using external RAM is here:
http://www.nongnu.org/avr-libc/user-manual/malloc.html
If you want total flexibility, you need to learn about linker scripts.
Together with section-attributes On variables, you can control what Gose
where. But not typically Arduino, but, you already attached external
memory, so you are Not a newby ;-)
Sorry for spelling, but iPad likes TO write German ;-)
Rate this post
useful
not useful
Thank you I will have a look at the site.
Yeah i am also German so no problem ;)
Thank you! :)
von Peter (Guest)
Rate this post
useful
not useful
I really would like to understand and see how such thing like ram
expansion can be done. Maybe when time allows you can show details with
pictures and explanations...
(I dont mean spi ram or similiar)
Peter
Rate this post
useful
not useful
http://andybrown.me.uk/2011/08/28/512kb-sram-expansion-for-the-arduino-mega-design/
This Tutorial gave me a very good entry point. The RAM from the mega
2560 can easily be expanded (up to 64kb) with an SRAM chip and an octal
tri state latch with d-latch in it.
In the Tutorial is everything mentioned what you need to expand the RAM
except of setting the registers for letting the MCU know what you are
doing ;) this can be read in the official documentations of the Mega
2560. The linker stuff is also not mentioned in the Tutorial ^^ Thats
why I was asking here ;)
Have fun Peter! :)
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
