EmbDev.net
Forum: ARM programming with GCC/GNU tools armv6 issues
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von July J. (julyjim)
Rate this post
useful
not useful
I need to change compiler from arm7 to armv6.
When I add -march=armv6 to miscellaneous as option I get the following
error:
Here is a part of the output, full output can be posted if it helps to
solve this.
                from ../src/ZERO_RPI.cpp:9:
/usr/arm-linux-gnueabihf/include/c++/5/exception: In constructor
‘std::exception::exception()’:
/usr/arm-linux-gnueabihf/include/c++/5/exception:63:39: sorry,
unimplemented: Thumb-1 hard-float VFP ABI
     exception() _GLIBCXX_USE_NOEXCEPT { }
make: *** [src/ZERO_RPI.o] Error 1
src/subdir.mk:18: recipe for target 'src/ZERO_RPI.o' failed
I can “fix” the  error by adding -marm  to the options.
The C++ code then compiles but does not run properly.
1. What does Thumb do?
2. Do I have to add it to compiler with armv6 addition and how?
3. Am I missing some other option to make the compiler happy and make
the code run ?
Any help will be appreciated
von olibert (Guest)
Rate this post
useful
not useful
There are really many Google hits describing the cause and the solution
like this one:
https://stackoverflow.com/questions/35132319/build-for-armv6-with-gnueabihf
They mostly replaced "-march=armv6" by "-marm" but you added it?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
