EmbDev.net
Forum: ARM programming with GCC/GNU tools Trying to get C++ projct running on AT91SAM9G20-EK on SDRAM
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Robin Mueller (Guest)
Rate this post
useful
not useful
Hi there,
I've been trying for some days to get a C++ project running.
Unfortunately, there appears to be a problem with the board startup
script and the linker script which were provided and are propably
generated. These files we initially not intended to incorporate C++ code
so now we're trying to adapt them to do just that. We are also using
freeRTOS. I attached the code of the two files
 *         ATMEL Microcontroller Software Support
 * Copyright (c) 2008, Atmel Corporation
 *      Linker script for running in external SDRAM on the AT91SAM9G20
_Min_Heap_Size = 0x400;      /* required amount of heap. Added manually  */
_Min_Stack_Size = 0x800;    /* required amount of stack. Added manually */
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
ENTRY(entry)
MEMORY
    sram0 (W!RX) : ORIGIN = 0x200000, LENGTH = 16K
23
    sram1 (W!RX) : ORIGIN = 0x300000, LENGTH = 16K
24
    sdram (W!RX) : ORIGIN = 0x20000000, LENGTH = 32M /* this board provided 64M, but we are just using  32M to model another device which only has 32M external SDRAM */
25
26
27
SECTIONS
28
29
    .fixed :
30
31
        . = ALIGN(4);      /* tells the linker that these section ought to be word aligned */
32
        _sfixed = .;
33
    KEEP(*(.startup));
34
        *(.text*)        /* Code is placed in .text */
35
        *(.rodata*)        /* global variables marked as const. are placed in .rodata */
36
        *(.glue_7)        /* glue arm to thumb code */
37
        *(.glue_7t)        /* glue thumb to arm code */
38
        *(.eh_frame)
39
        *(.data)
40
        *(.data*)        /* contains all initialized global and static variables */
41
        *(.CP15_*)  /* required for system control coprocessor? */
42
        KEEP (*(.init))
43
      KEEP (*(.fini))
44
        . = ALIGN(4);
45
    /* preinit data */
46
    PROVIDE_HIDDEN (__preinit_array_start = .);
47
    KEEP(*(.preinit_array))
48
    PROVIDE_HIDDEN (__preinit_array_end = .);
49
50
    . = ALIGN(4);
51
    /* init data, the constructors are placed in this sections */
52
    PROVIDE_HIDDEN (__init_array_start = .);
53
    KEEP(*(SORT(.init_array.)))
54
    KEEP(*(.init_array))
55
    PROVIDE_HIDDEN (__init_array_end = .);
56
57
    . = ALIGN(4);
58
    /* finit data, destructors are placed in this section */
59
    PROVIDE_HIDDEN (__fini_array_start = .);
60
    KEEP(*(SORT(.fini_array.)))
61
    KEEP(*(.fini_array))
62
    PROVIDE_HIDDEN (__fini_array_end = .);
63
  } >sdram
64
65
  .ARM.extab (NOLOAD) : {
66
    *(.ARM.extab* .gnu.linkonce.armextab.*)
67
  } >sdram
68
69
  __exidx_start = .;
70
    .ARM.exidx (NOLOAD) : {
71
    *(.ARM.exidx* .gnu.linkonce.armexidx.*)
72
  } > sdram
73
    __exidx_end = .;
74
    _efixed = .;
75
76
    .prerelocate : AT (_efixed) /* all relocation stuff is pretty much taken from atmel */
77
78
        . = ALIGN(4);
79
        _sprerelocate = .;
80
        . = ALIGN(4);
81
        _eprerelocate = .;
82
83
84
    .postrelocate : AT (_sprerelocate + SIZEOF(.prerelocate))
85
86
        . = ALIGN(4);
87
        _spostrelocate = .;
88
        KEEP(*(.vectors));
89
    *(.sramfunc)
90
        *(.ramfunc)
91
        . = ALIGN(4);
92
        _epostrelocate = .;
93
    } >sram0
94
95
96
    /* this section holds uninitialized global and static data  */
97
   . = ALIGN(4);
98
  .bss :
99
100
      /* This is used by the startup in order to initialize the .bss secion */
101
      _sbss = .;         /* define a global symbol at bss start */
102
      __bss_start__ = _sbss;
103
      *(.bss)
104
      *(.bss*)
105
      *(COMMON)
106
107
      . = ALIGN(4);
108
      _ebss = .;         /* define a global symbol at bss end */
109
      __bss_end__ = _ebss;
110
    } >sdram
111
112
    /* User_heap_stack section, used to check that there is enough RAM left */
113
    ._user_heap_stack :
114
115
      . = ALIGN(4);
116
      PROVIDE ( end = . );
117
      PROVIDE ( _end = . );
118
      . = . + _Min_Heap_Size;
119
      . = . + _Min_Stack_Size;
120
      . = ALIGN(4);
121
    } >sdram
122
123
  /* top of stack */
124
    _sstack = 0x22000000 - 1024;
125
And the start up script:
//         Headers
#include "board.h"
//         Definitions
#define IRQ_STACK_SIZE   8*3*4
#define ARM_MODE_ABT     0x17
#define ARM_MODE_FIQ     0x11
#define ARM_MODE_IRQ     0x12
23
#define ARM_MODE_SVC     0x13
24
25
#define I_BIT            0x80
26
#define F_BIT            0x40
27
28
29
//         Startup routine
30
31
32
            .align      4
33
            .arm
34
35
/* Exception vectors
36
37
            .section    .vectors, "a", %progbits
38
39
resetVector:
40
        ldr     pc, =resetHandler       /* Reset */
41
undefVector:
42
        b       undefVector             /* Undefined instruction */
43
swiVector:
44
    ldr     pc, =vPortYieldProcessor /* Software interrupt */
45
46
prefetchAbortVector:
47
        b       prefetchAbortVector     /* Prefetch abort */
48
dataAbortVector:
49
        b       dataAbortVector         /* Data abort */
50
reservedVector:
51
        b       reservedVector          /* Reserved for future use */
52
irqVector:
53
        b       irqHandler              /* Interrupt */
54
fiqVector:
55
                                        /* Fast interrupt */
56
57
/// Handles a fast interrupt request by branching to the address defined in the
58
/// AIC.
59
60
fiqHandler:
61
        b       fiqHandler
62
63
64
/// Handles incoming interrupt requests by branching to the corresponding
65
/// handler, as defined in the AIC. Supports interrupt nesting.
66
67
irqHandler:
68
69
/* Save interrupt context on the stack to allow nesting */
70
        sub     lr, lr, #4
71
        stmfd   sp!, {lr}
72
        mrs     lr, SPSR
73
        stmfd   sp!, {r0, lr}
74
75
/* Write in the IVR to support Protect Mode */
76
        ldr     lr, =AT91C_BASE_AIC
77
        ldr     r0, [lr, #AIC_IVR]
78
        str     lr, [lr, #AIC_IVR]
79
80
/* Branch to interrupt handler in Supervisor mode */
81
        msr     CPSR_c, #ARM_MODE_SVC
82
        stmfd   sp!, {r1-r3, r4, r12, lr}
83
        blx     r0
84
85
/* Restore scratch/used registers and LR from User Stack */
86
/* Disable Interrupt and switch back in IRQ mode */
87
        ldmia   sp!, {r1-r3, r4, r12, lr}
88
        msr     CPSR_c, #ARM_MODE_IRQ | I_BIT
89
90
/* Acknowledge interrupt */
91
92
        str     lr, [lr, #AIC_EOICR]
93
94
/* Restore interrupt context and branch back to calling code */
95
        ldmia   sp!, {r0, lr}
96
        msr     SPSR_cxsf, lr
97
        ldmia   sp!, {pc}^
98
99
100
/// Initializes the chip and branches to the main() function.
101
102
            .section    .text
103
            .global     entry
104
105
entry:
106
resetHandler:
107
108
/* Useless instruction for referencing the .vectors section */
109
        ldr     r0, =resetVector
110
111
/* Set pc to actual code location (i.e. not in remap zone) */
112
      ldr     pc, =1f
113
114
/* Initialize the prerelocate segment */
115
1:
116
        ldr     r0, =_efixed
117
        ldr     r1, =_sprerelocate
118
        ldr     r2, =_eprerelocate
119
1:
120
        cmp     r1, r2
121
        ldrcc   r3, [r0], #4
122
        strcc   r3, [r1], #4
123
        bcc     1b
124
125
/* Perform low-level initialization of the chip using LowLevelInit() */
126
        ldr     sp, =_sstack
127
        stmfd   sp!, {r0}
128
      ldr     r0, =LowLevelInit
129
        blx     r0
130
131
/* Initialize the postrelocate segment */
132
133
        ldmfd   sp!, {r0}
134
        ldr     r1, =_spostrelocate
135
        ldr     r2, =_epostrelocate
136
1:
137
        cmp     r1, r2
138
        ldrcc   r3, [r0], #4
139
        strcc   r3, [r1], #4
140
        bcc     1b
141
142
/* Clear the zero segment */
143
      ldr     r0, =__bss_start__
144
        ldr     r1, =__bss_end__
145
        mov     r2, #0
146
1:
147
        cmp     r0, r1
148
        strcc   r2, [r0], #4
149
        bcc     1b
150
151
/* Setup stacks
152
153
/* IRQ mode */
154
        msr     CPSR_c, #ARM_MODE_IRQ | I_BIT | F_BIT
155
        ldr     sp, =_sstack
156
        sub     r4, sp, #IRQ_STACK_SIZE
157
158
/* Supervisor mode (interrupts enabled) */
159
        msr     CPSR_c, #ARM_MODE_SVC | F_BIT
160
        mov     sp, r4
161
162
/* Call static constructors */
163
      ldr r0,=__libc_init_array
164
    mov lr,pc /* set the return address */
165
    bx r0 /* the target code can be ARM or THUMB */
166
/* Branch to main()
167
168
        ldr     r0, =main
169
        blx     r0
170
171
/* Loop indefinitely when program is finished */
172
1:
173
        b       1b
Do you have any idea why are program is crashing randomly? Right now it
always crashes and jumps to an adress it is not intended to be. I
attached the dissassembly when  this happends while debugging.
My guess is that this relates to the two files shown above. Maybe
something is missing so that C++ is working properly? The program
crashes when the freeRTOS task scheduler has already started. I hope
someone has a clue how  to get this working. Especially someone who
managed to get C++ working on ARM processors. Thanks a lot in advance !
Kind Regards,
Robin
von Robin M. (spacefish)
Rate this post
useful
not useful
The program does not crash anymore when I comment out code related to
hardware drivers. The program does not crash when performing these
functions but crashes at the adresses I have shown in the 2 pictures.
This is really confusing.
I use the AT91SAM9G20-EK board and provided drivers. This is inside a
function which is called by performOperation() which crashed
//ATMEL
AT91S_USART * rs232; // do not initialize this register handle, causes problems !
USART_Configure(rs232, AT91C_US_USMODE_NORMAL,9600,BOARD_MCK);
USART_SetReceiverEnabled(rs232, true);
USART_SetTransmitterEnabled(rs232,true);
result = USART_IsDataAvailable(rs232);
if(result==1) {
  info << "Data available !" << std::endl;
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
