EmbDev.net
Forum: DSP Extracting filter coefficients from fdatool IIR filter object
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Jefazo J. (jefazo92)
Rate this post
useful
not useful
Hi everyone,
I have designed an IRR filter in fdatool but since I can't export the
coefficients as a vector into the workspace, I exported the filter as an
object. The problem is that when I open the object, I have 3 arrays
stored in it (ScaleValues, States and sosMatrix). Please, could someone
exlplain me the difference between each array and, more importantly, how
I can extract the filter coefficients from my IRR filter ? Also if you
could write down links to official sources/documentation, it would
amazing. Please any help would be really appreciated. Thank you in
advance.
P.S. I am converting my structure to Direct-Form 1since, supposedly, it
gives the coefficients for the ideal IRR filter or is, at least, more
accurate but I am also not sure about it and if soemone could also
explain me what it is exactly, it would be greatly appreciated.
Also, I am using a Lowpass Chebyshev Type II filter for my IIR. Thank
you.
von Joe F. (easylife)
Rate this post
useful
not useful
I'm not a mathlab user but looking at this
https://www.mathworks.com/help/signal/ref/sos2tf.html
leads me to the assumption that "sos" stands for "second-order section"
and is an n x 6 array containing the IIR coefficients.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
