EmbDev.net
Forum: µC & Digital Electronics Arduino Project: FrSky S.Port (Smart.Port) data transfer with Beetle ATMEGA23u4 via softwareserial
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Arno Waldmann (Guest)
Rate this post
useful
not useful
I have developed a telemetry module for FrSky Smart.Port that works
without any problems. As shown in the attachment I use an ATMEGA Beetle
for the telemetry data transmission which is connected to the port D11
and the S.Port on the RX8R.
The serial data transfer on the Beetle is done with the SoftwareSerial
library with signal inversion.
What I cannot explain is why the TTL levels of the two communication
partners are so different. The TTL level from the receiver has a little
over 3V peak and the Beetle is also coming in at 1.67V.
I have no clue why that is so!
What can I do about it, for example, use a transceiver ...?
von stefanus (Guest)
Rate this post
useful
not useful
You possible measured between 5V and the signal wire. When the µC is
powered with 3,3V and outputs HIGH (3,3V), the difference you measure is
1,7V.
Rate this post
useful
not useful
The operating voltage 5V
von Arno W. (horido)
Rate this post
useful
not useful
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
