EmbDev.net
Forum: FPGA, VHDL & Verilog Verilog on GW1NZ-1 - why not work :-(
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Kajetan K. (kmk68)
Rate this post
useful
not useful
Hello,
I have a lot of experience in analog and digital electronics
(30 years is quite a lot, I think. The first ten years professionally)
and quite a lot in programming (the last 20 years professionally) :-)
Well I am no longer young, fact, and I took to such novelties
such as Verilog ;-)
Here I am a novice. This is my first layout.
I need a multiplexer and demultiplexer for a device
in which I don't have enough space to simply add a board
Universal with several CMOS chips.
So I came up with that I would use the GOVIN GW1NZ-1 universal board.
The code as below. It is not complicated. It compiles without
errors and warnings. It programs without error messages
Both to SRAM memory and to embedded FLASH.
Only - after programming the circuit does not work - it does not respond
to the switching address lines and csel. NOTHING.
Maybe I don't know something, maybe I forgot something? Code is
attached. It is not large.
Please help me.
von Vancouver (vancouver)
Rate this post
useful
not useful
So, the simulation behaves as expected, I assume?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
