www.mikrocontroller.net
ARM GCC toolchain for Linux and Mac OS X
Update (2007-04-20): added Mac OS X Intel version
This package is intended for and was tested with small ARM microcontrollers like LPC21xx, AT91SAM7, ST7, ADuC7000, but should work for any system supported by arm-elf. Take a look at the configuration of the components below to find out whether it suits your application.
Inhaltsverzeichnis
[bearbeiten] Content (Build 2)
This build is similar to Martin Thomas' WinARM package. The main difference to GNUARM is that in WinARM and this build Newlib is compiled with the option -DREENTRANT_SYSCALLS_PROVIDED, as recommended in Bill Gatliff's article "Porting and Using Newlib in Embedded Systems".
  • Binutils 2.16.1 configured with --target=arm-elf --enable-interwork --enable-multilib
  • GCC 4.1.0 with patched t-arm-elf, configured with --target=arm-elf --enable-interwork --enable-multilib --enable-languages="c,c++" --with-newlib
  • Newlib 1.14.0 configured with --target=arm-elf --enable-interwork --enable-multilib and -DREENTRANT_SYSCALLS_PROVIDED
  • GDB 6.4 configured with --target=arm-elf --enable-interwork --enable-multilib
Everything is built with --prefix=/usr/local/arm. The Linux version is compiled with Debian Sarge, the Mac OS X PPC version with 10.3 (Panther), the Mac OS Intel Version with 10.4 (Tiger). All binaries are stripped. The build process on Linux and Mac OS X is identical.
[bearbeiten] Download
[bearbeiten] Installation
cd /tmp
# download
curl -O -C - http://www.mikrocontroller.net/download/arm-toolchain-macosx-2.tar.bz2
# extract
tar xjvf arm-toolchain-macosx-2.tar.bz2
# install
sudo mv arm /usr/local/
# add /usr/local/arm/bin to your path permanently
echo 'export PATH=/usr/local/arm/bin:$PATH' >> ~/.profile
[bearbeiten] Support forum
If you have any questions regarding this toolchain build or want to discuss ARM-GCC programming in general, please visit the forum.
[bearbeiten] Related websites
webmaster@mikrocontroller.netImpressumWerbung auf Mikrocontroller.net
