AVR ASM Befehlsübersicht
Die Abkürzungen in der Tabelle bedeuten:
r1 ---- Allgemeines Quell- und Zielregister R0..R31<br>
r2 ---- Allgemeines Quellregister
rh ---- Oberes Register R16..R31
rd ---- Doppelregister R24(R25), R26(R27), R28(R29), R30(R31)
rp ---- Pointerregister X=R26(R27), Y=R28(R29), Z=R30(R31)
ry ---- Pointerregister mit Ablage Y=R28(R29), Z=R30(R31)
k63 --- Pointer-Konstante 0..63
k127 -- Bedingte Sprungdistanz -64..+63
k255 -- 8-Bit-Konstante 0..255
k4096 - Relative Sprungdistanz -2048..+2047
k65535 16-Bit-Adresse 0..65535
Bit --- b7 Bitposition 0..7
Port -- p1 Beliebiger Port 0..63
pl ---- Unterer Port 0..31
| Funktion | Unterfunktion | Befehl | Flags | Clk |
Register setzen | 0 | CLR r1 | Z N V | 1 |
| 255 | SER rh | | | 1 |
| Konstante | LDI rh,k255 | | | 1 |
| Kopieren | Register => Register | MOV r1,r2 | | 1 |
| SRAM => Register, direkt | LDS r1,k65535 | | 2 |
| SRAM => Register | LD r1,rp | | 2 |
| SRAM => Register mit INC | LD r1,rp+ | | 2 |
| DEC, SRAM => Register | LD r1,-rp | | 2 |
| SRAM, indiziert => Register | LDD r1,ry+k63 | | 2 |
| Port => Register | IN r1,p1 | | 1 |
| Stack => Register | POP r1 | | 2 |
| Programmspeicher Z => R0 | LPM | | 3 |
| Register => SRAM, direkt | STS k65535,r1 | | 2 |
| Register => SRAM | ST rp,r1 | | 2 |
| Register => SRAM mit INC | ST rp+,r1 | | 2 |
| DEC, Register => SRAM | ST -rp,r1 | | 2 |
| Register => SRAM, indiziert | STD ry+k63,r1 | | 2 |
| Register => Port | OUT p1,r1 | | 1 |
| Register => Stack | PUSH r1 | | 2 |
| Addition | 8 Bit, +1 | INC r1 | Z N V | 1 |
| 8 Bit | ADD r1,r2 | Z C N V H | 1 |
| 8 Bit+Carry | ADC r1,r2 | Z C N V H | 1 |
| 16 Bit, Konstante | ADIW rd,k63 | Z C N V S | 2 |
| Subtraktion | 8 Bit, -1 | DEC r1 | Z N V | 1 |
| 8 Bit | SUB r1,r2 | Z C N V H | 1 |
| 8 Bit, Konstante | SUBI rh,k255 | Z C N V H | 1 |
| 8 Bit - Carry | SBC r1,r2 | Z C N V H | 1 |
| 8 Bit - Carry, Konstante | SBCI rh,k255 | Z C N V H | 1 |
| 16 Bit | SBIW rd,k63 | Z C N V S | 2 |
| Schieben | Logisch, links | LSL r1 | Z C N V | 1 |
| Logisch, rechts | LSR r1 | Z C N V | 1 |
| Rotieren, links über Carry | ROL r1 | Z C N V | 1 |
| Rotieren, rechts über Carry | ROR r1 | Z C N V | 1 |
| Arithmetisch, rechts | ASR r1 | Z C N V | 1 |
| Nibbletausch | SWAP r1 | | 1 |
| Binär | Und | AND r1,r2 | Z N V | 1 |
| Und, Konstante | ANDI rh,k255 | Z N V | 1 |
| Oder | OR r1,r2 | Z N V | 1 |
| Oder, Konstante | ORI rh,k255 | Z N V | 1 |
| Exklusiv-Oder | EOR r1,r2 | Z N V | 1 |
| Einer-Komplement | COM r1 | Z C N V | 1 |
| Zweier-Komplement | NEG r1 | Z C N V H | 1 |
Bits ändern | Register, Setzen | SBR rh,k255 | Z N V | 1 |
| Register, Rücksetzen | CBR rh,255 | Z N V | 1 |
| Register, Kopieren nach T-Flag | BST r1,b7 | T | 1 |
| Register, Kopie von T-Flag | BLD r1,b7 | | 1 |
| Port, Setzen | SBI pl,b7 | | 2 |
| Port, Rücksetzen | CBI pl,b7 | | 2 |
Statusbit setzen | Zero-Flag | SEZ | Z | 1 |
| Carry Flag | SEC | C | 1 |
| Negativ Flag | SEN | N | 1 |
| Zweierkompliment Überlauf Flag | SEV | V | 1 |
| Halbübertrag Flag | SEH | H | 1 |
| Signed Flag | SES | S | 1 |
| Transfer Flag | SET | T | 1 |
| Interrupt Enable Flag | SEI | I | 1 |
Statusbit rücksetzen | Zero-Flag | CLZ | Z | 1 |
| Carry Flag | CLC | C | 1 |
| Negativ Flag | CLN | N | 1 |
| Zweierkompliment Überlauf Flag | CLV | V | 1 |
| Halbübertrag Flag | CLH | H | 1 |
| Signed Flag | CLS | S | 1 |
| Transfer Flag | CLT | T | 1 |
| Interrupt Enable Flag | CLI | I | 1 |
| Vergleiche | Register, Register | CP r1,r2 | Z C N V H | 1 |
| Register, Register + Carry | CPC r1,r2 | Z C N V H | 1 |
| Register, Konstante | CPI rh,k255 | Z C N V H | 1 |
| Register, ≤0 | TST r1 | Z N V | 1 |
Unbedingte Verzweigung | Relativ | RJMP k4096 | | 2 |
| Indirekt, Adresse in Z | IJMP | | 2 |
| Unterprogramm, relativ | RCALL k4096 | | 3 |
| Unterprogramm, Adresse in Z | ICALL | | 3 |
| Return vom Unterprogramm | RET | | 4 |
| Return vom Interrupt | RETI | I | 4 |
Bedingte Verzweigung | Statusbit gesetzt | BRBS b7,k127 | | 1/2 |
| Statusbit rückgesetzt | BRBC b7,k127 | | 1/2 |
| Springe bei gleich | BREQ k127 | | 1/2 |
| Springe bei ungleich | BRNE k127 | | 1/2 |
| Springe bei Überlauf | BRCS k127 | | 1/2 |
| Springe bei Carry=0 | BRCC k127 | | 1/2 |
| Springe bei gleich oder größer | BRSH k127 | | 1/2 |
| Springe bei kleiner | BRLO k127 | | 1/2 |
| Springe bei negativ | BRMI k127 | | 1/2 |
| Springe bei positiv | BRPL k127 | | 1/2 |
| Springe bei größer oder gleich (Vorzeichen) | BRGE k127 | | 1/2 |
| Springe bei kleiner Null (Vorzeichen) | BRLT k127 | | 1/2 |
| Springe bei Halbübertrag | BRHS k127 | | 1/2 |
| Springe bei HalfCarry=0 | BRHC k127 | | 1/2 |
| Springe bei gesetztem T-Bit | BRTS k127 | | 1/2 |
| Springe bei gelöschtem T-Bit | BRTC k127 | | 1/2 |
| Springe bei Zweierkomplementüberlauf | BRVS k127 | | 1/2 |
| Springe bei Zweierkomplement-Flag=0 | BRVC k127 | | 1/2 |
| Springe bei Interrupts eingeschaltet | BRIE k127 | | 1/2 |
| Springe bei Interrupts ausgeschaltet | BRID k127 | | 1/2 |
Bedingte Sprünge | Registerbit=0 | SBRC r1,b7 | | 1/2/3 |
| Registerbit=1 | SBRS r1,b7 | | 1/2/3 |
| Portbit=0 | SBIC pl,b7 | | 1/2/3 |
| Portbit=1 | SBIS pl,b7 | | 1/2/3 |
| Vergleiche, Sprung bei gleich | CPSE r1,r2 | | 1/2/3 |
| Andere | No Operation | NOP | | 1 |
| Sleep | SLEEP | | 1 |
| Watchdog Reset | WDR | | 1 |
Autor: Megges
