EmbDev.net
Forum: ARM programming with GCC/GNU tools flatten function attribute
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Joe (Guest)
Rate this post
useful
not useful
Has anyone had success with __attribute__((flatten)) using yagarto?
I have tried various locations of the attribute tag in the function
declaration or definition, but it appears the attribute is completely
ignored.
void test_flatten(void) __attribute__((flatten));
void test_flatten(void){
    function1();
    function2();
From what I understand, flatten is supposed to "inline" all calls within
a function, essentially creating one large "stand-alone" function.  When
I step through the supposedly flattened code, there are still "bl"
instructions to function1() and function2() locations.
von Joe D. (jdupre)
Rate this post
useful
not useful
I should add that the docs say "The flatten attribute only works
reliably in unit-at-a-time mode. ", which should be enabled with
optimization -O1. But I still get don't get the single monolithic block
of code I expect, there are still branches to the other functions.
von Rolf Magnus (Guest)
Rate this post
useful
not useful
> a function
... "if possible". Did you define those two functions in the same
implementation file as your test_flatten function? If they are
implemented in a different one, they can't be inlined.
von Joe D. (jdupre)
Rate this post
useful
not useful
No.  One of the functions was in a different file.
von Prakash (Guest)
Rate this post
useful
not useful
I am using GCC version 9 in Ubuntu 14.04
I have defined two function in the same file and one of the function is
attributed as "flatten" but But I still did not get the single
monolithic block of code I expect, there are still branches to the other
functions.
Why exactly it is not following the flatten attribute concept ?
Here is the code
void __attribute__((flatten)) hot_code();
void do_thing(int input)
    int val;
    val = input;
    int x = 5;
    while (x<10) {
        do_thing(x);
        x++;
Rate this post
useful
not useful
void hot_code() __attribute__((flatten));
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
