EmbDev.net
Forum: ARM programming with GCC/GNU tools Migrating from Keil to GCC
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Trevor J. (trevor_j)
Rate this post
useful
not useful
I just recently switched my development environment to Linux and am
wanting to use gcc as my toolchain from now on but have a few questions.
Notably Keil's toolchain is ELF however I see that everyone seems to be
using EABI. I understand the ELF layout but their is not as much info on
EABI. What is the benefits of this new format?
I have used CodeSourcery Lite to compile some test apps and I have also
built my own arm-none-eabi toolchain tailored to my Cortex-M3 and I know
both work but I am wondering for the standard c library does
CodeSourcery install its own support libraries or does it use the system
version of stdint.h? I'm somewhat new to where everything is placed in
the Linux file system. Ideally I would have the entire toolchain in one
self contained directory.
Debugging is a huge difference between Keil's uVision4 and Insight/DDD
or even Eclipse. I am considering writing a plugin to give the same
Peripheral overview as uVision as this is a nice way to check the setup
otherwise you need to probe around in memory and check bit values with a
1000page datasheet.
Does anybody know a walkthrough on setting up Eclipse for CodeSourcery
with debugging and everything?
ITM/ETM, I use ITM extensively thought my programs and uVision4 handled
this automatically with its debug terminal. How do I use this feature
through the command line tools such as GDB/Insignt or even Eclipse?
von Martin T. (mthomas) (Moderator)
Rate this post
useful
not useful
Please read a little bit on "ELF" here:
http://en.wikipedia.org/wiki/Executable_and_Linkable_Format. You may
compare the "elf-File" with the "axf-File" generated by the Realview
tools (IRC the internal Format is at least similar).
The Binary-Interface is something different. Realview uses the EABI. The
GNU tools can be configured for the "old"-ABI or EABI (see
configurationen parameter target).
CS G++ lite comes with a libc. It's the newlib, see libc.pdf in the
documentation installed be CS G++ and/or visit
http://sourceware.org/newlib/
As far as I know CS G++ lite for ARM-EABI and Linux hosts comes with a
small install-script which installs the cross tool-chain, it's libraries
(libc, libgcc) and the header-files in a subdirectory of /opt. You may
use CS's structure as template.
> 1000page datasheet.
The is a special functions register view plugin for Eclipse on sf.net
but I have not played with it so far.
If you need something like a "printf via JTAG-interface" (DCC): OpenOCD
supports  the reception of characters "sent" through the
debug-data-register (see OpenOCD manual: target_request debugmsgs
Rate this post
useful
not useful
Thanks for the answers!
Wiki does not have the best answers on ELF and EABI but I am fimilar
with ELF and its organization makes since to me. EABI appears to be very
similar to ELF except that it also defines call and memory structures.
Can you link ELF's output from two different compilers? EABI apparently
can and thats handy when you have dynamic libs on the system.
Reilview outputs EABI? when converting the axf to a hex file for
programming the documentation says its converting from ELF.
I looked up 'target_request debugmsgs' in the OpenOCD manual and boy
theirs not much of a description in there. In uVision I had to connect
via SWO and not JTAG and then enable TRACE_IOEN in the DBGMCU_CR to
start receiving via ITM. Is their a better description of how to
actually go about setting this up via OpenOCD?
Rate this post
useful
not useful
Why do you try to compare a binary-interface (like "old" ABI or EABI)
with an output-format of a linking (like ELF)?
As far as I know object-code using EABI from different compilers can be
linked.
The usual file-extension used for outputs of Realview's Linker is axf.
The usual file-extension when using GNU tools is elf. But these are just
file-extensions, I expect internally both files are in ELF maybe with a
few more/less sections. The forum on keil.com might be a better place to
ask internal and technical questions on Realview and µVision.
Can not comment on µVision's trace functionality. More information on
OpenOCD and "printf" via debug-interface:
http://repo.or.cz/w/openocd.git/tree/master:/contrib/libdcc . For
further information you may also ask in the OpenOCD-forum at sparkfun or
in the OpenOCD developer mailing list.
Rate this post
useful
not useful
Fantastic! Thats even easier to use than uVisions version as you must
manually retarget putc() to print to the ITM registers and set up those
registers correctly.
Thanks for the help!
von Spencer O. (ntfreak)
Rate this post
useful
not useful
Just thought i would mention another possibility when using codesourcery
toolchain.
Codesourcery as Martin has already mentioned is based on newlib.
However they also have there own lib (cs3) layer that can also be used
for semi-hosting. If you link with libcs3hosted.a rather than
libcs3unhosted.a you are able to use this with openocd.
for this to work enable with:
arm semihosting enable
Not only can you do normal things like printf to console, but you can
also open/read/write files on your local pc - great for logging without
having to write a filesystem etc.
Cheers
Spen
von Shailesh Narendra Bakshi (Guest)
Rate this post
useful
not useful
Please convert this project to stm32 workbech project
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
