EmbDev.net
Forum: µC & Digital Electronics AVR clock prescaler (CLKPR) and gcc code optimization
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Peter-Jan P. (pjp)
Rate this post
useful
not useful
Since I spend the last two days trying to get the clock prescaler to
work I wanted to share my results. Everything I write here has been
tested with an attiny2313. Anyway this problem exists with other AVR
microcontrollers as well.
To set for clock prescaling factor it is necessary to access the CLKPR
twice within 4 clock cycles. First you set the highest bit (CLKPCE) to 1
and all others to 0. Then you write the actual value for CLKPR. avr-gcc
code could look like this:
  CLKPR = (1<<CLKPCE);
  CLKPR = 1;
As long as code optimizatin is used (gcc option -Os) everything works as
expected. If no optimization is used (-O0), the above code has no
effect. The clock prescaling factor isn't changed. The reason for this
can be found in the respective assembler code.
With optimization you get:
  ldi r24,lo8(-128)   ;  tmp44,
  out 70-32,r24   ; ,, tmp44
  ldi r24,lo8(1)   ;  tmp46,
  out 70-32,r24   ; ,, tmp46
without optimization this becomes
  ldi r24,lo8(70)   ;  D.2172,
  ldi r25,hi8(70)   ;  D.2172,
  ldi r18,lo8(-128)   ;  tmp54,
  movw r30,r24   ; , D.2172
  st Z,r18   ; , tmp54
  ldi r24,lo8(70)   ;  D.2173,
  ldi r25,hi8(70)   ;  D.2173,
  ldi r18,lo8(1)   ;  tmp55,
  movw r30,r24   ; , D.2173
  st Z,r18   ; , tmp55
Obviously the register access (the lines with "st Z,r18") is not done
If you do not want to use code optimization, you can circumvent the
problem by using an inline assembler statement like this one:
  asm volatile (
    "st Z,%1" "\n\t"
    "st Z,%2"
    "z" (&CLKPR),
    "r" ((uint8_t) (1<<CLKPCE)),
    "r" ((uint8_t) 1)  // new CLKPR value
von MWS (Guest)
Rate this post
useful
not useful
Since you've spent two days senselessly, as you either forgot to, or you
don't know how to read the documentation, there's a certain chance
you'll do it next time more clever.
Anyway, it doesn't make you look smarter, if you post the same proof
that you had blinders on, in English too.
Beitrag "AVR clock prescaler (CLKPR) und gcc-Codeoptimierung"
The solution is simple: use clock_prescale_set(x) from power.h
von DFA (Guest)
Rate this post
useful
not useful
PJP,
I am new to ATMEL and found your posting here very helpful.  I do not
bash people for not reading documentation or missing some particular
part of the documentation.  I would not have known to go to a seemingly
unrelated file like "power.h" to find out about setting the clock
prescaler.
Keep up your good work here. I look forward to seeing what you discover.
DFA
von RT (Guest)
Rate this post
useful
not useful
PJP,
Thank you for this. I had also the same problem, as I was in debug mode
and the prescaler would not change.
@MWS I am gratefull he posted it in English as wel. Also not everyone
uses the libraries provided by Arduino.
von Jörg W. (dl8dtl) (Moderator)
Rate this post
useful
not useful
RT wrote:
> Also not everyone uses the libraries provided by Arduino.
The header file mentioned is part of avr-libc (and thus in no relation
to "Arduino libraries"), and this particular inline function has been
provided there for exactly the purpose the TO tried to solve with his
own inline asm macro: being independent of the compiler optimization.
Of course, everyone is free to roll their own … and making their own
mistakes (like, in this case, not thinking about whether interrupts need
to be disabled - the inline function in avr/power.h takes care about
that).
: Edited by Moderator
von c-hater (Guest)
Rate this post
useful
not useful
Yes, that's the truth. But it is NOT PORTABLE.
Those guys are the guys, who're REALLY know, what they're doing. The
advantage is: they drop any dependencies to any specific compiler.
That's the only way to get really free. Gain own knowledge regarding the
target. Don't become a stupid slave of one specific compiler.
> mistakes
Of course. Making the own mistakes is the only way to generate foundated
knowledge.
This is a very widely accepted fact.
von Johann L. (gjlayde)
Rate this post
useful
not useful
Jörg W. wrote:
> and this particular inline function has been provided there
In avr/power.h I find at line 1600:
void timer_clock_prescale_set(timer_clock_div_t __x)
    uint8_t __t;
    __asm__ __volatile__ (
        "in __tmp_reg__,__SREG__" "\n\t"
        "cli" "\n\t"
        "in %[temp],%[clkpr]" "\n\t"
        "out %[clkpr],%[enable]" "\n\t"
        "andi %[temp],%[not_CLTPS]" "\n\t"
        "or %[temp], %[set_value]" "\n\t"
        "out %[clkpr],%[temp]" "\n\t"
        "sei" "\n\t"
        "out __SREG__,__tmp_reg__" "\n\t"
        : /* no outputs */
        : [temp] "r" (__t),
          [clkpr] "I" (_SFR_IO_ADDR(CLKPR)),
          [enable] "r" (_BV(CLKPCE)),
          [not_CLTPS] "M" (0xFF & (~ ((1 << CLTPS2) | (1 << CLTPS1) | (1 << CLTPS0)))),
          [set_value] "r" ((__x & 7) << 3)
        : "r0");
http://svn.savannah.nongnu.org/viewvc/avr-libc/trunk/avr-libc/include/avr/power.h?revision=2525&view=markup#l1600
What's the rationale behind the SEI just prior to the final OUT?
Rate this post
useful
not useful
SEI takes effect just after the next instruction only.
von Peter D. (Guest)
Rate this post
useful
not useful
But it was overwritten by the following access to SREG. So it may be
omitted.
Rate this post
useful
not useful
OK ;-)
von Programmierer (Guest)
Rate this post
useful
not useful
Inline assembly is compiler specific and not portable at all. For
example, the original code contains "asm volatile (...". This is, in
fact, invalid C syntax, and will not compile with a standard-compliant
compiler (e.g. GCC when specifying -std=c99). The compiler will think
that "asm" is a function or type name and will indicate a syntax error.
By changing it to "__asm__ __volatile__", as in avr/power.h, it becomes
correct C, as now the compiler-specific keyword "__asm__" is used, which
the standard allows. Of course, it's still not portable, but at least
not invalid C.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
