EmbDev.net
Forum: FPGA, VHDL & Verilog XILINX XC3S50AN: Can't program internal Flash
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Oerg866 (Guest)
Rate this post
useful
not useful
Hi :)
I've written this post in both English and German - because the website
said I could do that. Neat!
Anyway, I created a small PCB equipped with an FPGA (XC3S50AN)) to do
some video processing. This is a first for me in two ways: I have
neither designed a PCB before nor have I used an FPGA. Previously I was
merely using CPLDs (XC9572XL) and protoboards :P
I ran into a problem which manifests itself in failure to program the
internal flash of the FPGA. I can run the IDCODE-Loop as many times as I
want and it will never fail. I can program the FPGA on the fly and the
board will come to life an do what it should. I've ironed out all the
bugs in the core and this the next step was programming the flash.
But no matter what I try, that doesn't work properly.
Below the post I've attached a log from iMPACT (by the way, I use ISE
12.4 with a Parallel Cable III clone).
As you can see, it erases, flashes and verifies properly - but why does
it still fail in the end? I've read about mode pins but I thought those
were for the non-"AN" series only, and I cannot see them in the
datasheet either (I use the TQ144 footprint, and the pinout doesn't have
any mode pins?)
Am I missing something? I would think so, because I'm a total newcomer
in this field...
Thanks in advance!
Eric
Hallöchen,
ich habe eine Platine entwickelt und benutze darauf einen FPGA (beides
sind für mich "firsts", vorher habe ich auf Proto-Boards und CPLDs
rumgeeiert :P)).
Also, folgendes. Ich kann den IDCODE-Test 99999999x ausführen, den FPGA
on-the-fly programmieren (platine tut dann auch, was sie soll), aber den
internen Flash kann ich, egal, was ich versuche, nicht programmieren.
iMPACT (ich benutze übrigens ISE 12.4 mit einem Parallel Cable III-Klon)
spuckt den untenstehenden Log aus.
Habe ich irgendetwas übersehen? Bin auf dem Gebiet wiegesagt Laie und
das Programmieren des Flashs ist das einzige was fehlschlägt, und das
kann ich mir nicht erklären...
Liebe Grüße
Eric
LOG:
INFO:iMPACT - Current time: So 23. Nov 01:52:43 2014
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 0.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/12.3/ISE_DS/ISE/spartan3a/data/xc3s50an_spi.cor.
'1': Downloading core...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1101 1111 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - Address 0x00000000 is in sector 0.
INFO:iMPACT - Start block = 0 for address 0x00000000.
INFO:iMPACT - Address 0x0000D587 is not located at the start of a sector boundary. The whole sector will be erased.
INFO:iMPACT - Address 0x0000D587 is in sector 2.
INFO:iMPACT - End block = 31 for address 0x0000D587.
23
24
25
26
27
28
29
30
31
32
33
'1': Erasing device...
34
done.
35
'1': Erasure completed successfully.
36
37
38
39
40
41
42
43
44
45
46
47
48
INFO:iMPACT - Address 0x00000000 is in page 0.
49
INFO:iMPACT - Address 0x0000D587 is in page 207.
50
'1': Programming Flash...done.
51
'1': Programming completed successfully.
52
53
54
'1': Verifying device...done.
55
'1': Verification completed successfully.
56
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and spi mode settings.
57
PROGRESS_END - End Operation.
58
Elapsed time =    105 sec.
von Oerg866 (Guest)
Rate this post
useful
not useful
I read about the mode and VS pins, and set them accordingly, and it
still doesn't work :(
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
The bitstream generator has an option called "drive done pin high". What
value do you have there?
Is a pull up connected to the done pin?
BTW: für Fragen in deutscher Sprache gehst du besser ins deutsche
mikrocontroller.net Mutterforum.
: Edited by Moderator
von Oerg866 (Guest)
Rate this post
useful
not useful
A friend already told me about that option and I checked the box next to
it. It still didn't work :(
Rate this post
useful
not useful
What is connected to the done pin? Did you measure the voltage at the
done pin? Do you have a schematic of your board?
And to what value did you set them? Why must I ask all those questions?
von Oerg866 (Guest)
Rate this post
useful
not useful
To valid values according to the datasheet, 0,1,1 for Mode, 1,1,1 vor
VS.
I redid the wires to those pins and the thing suddenly started working.
Hooray!
Case closed, was a bad connection SOMEWHERE :D
Cheers.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
