EmbDev.net
Forum: FPGA, VHDL & Verilog DS1305 and vhdl
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Max F. (maxfed)
Rate this post
useful
not useful
Hi all! I need to work with RTC DS1305 with Quartus (vhdl), can anybody
show me some examples? thnx
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Max Fed wrote:
> RTC DS1305
Excerpt from datasheet: Supports Motorola SPI
Then have a look at this (with google translator):
http://www.lothar-miller.de/s9y/categories/45-SPI-Master
von maxfed (Guest)
Rate this post
useful
not useful
Lothar, thank you for your code!
One more question:
HEX ADDRESS
READ WRITE Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 RANGE
00h   80h   0    10 Seconds       Seconds          00–59
01h   81h   0    10 Minutes       Minutes          00–59
So, how I write 0-s in seconds? Can you write in 2-3 lines of code? And
I'll understand all :))
: Edited by Moderator
Rate this post
useful
not useful
Have a look at "Figure 6. SPI SINGLE-BYTE WRITE"
You will need a 16 bit transfer with first byte is the address x"80" and
the second byte is x"00".
When you use my SPI master as a component in your toplevel design, then
you have just to write:
   TX_Data  <= x"8000";
   TX_Start <= '1';
It gets more tricky if you want to access several registers one after
the other, because this successive access must be done by a state
machine: steps are always the same: config a transmission, start the
transmission, wait for the transmissions end, then config a
transmission, start it, wait for its end, and so on.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
