EmbDev.net
Forum: DSP FIR-bandpass and Hilbert-flter in one?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von W.S. (Guest)
Rate this post
useful
not useful
hallo together,
today I have a little question: Is it possible to turn a common
FIR-bandpass into a bandpass with 90 degree phase shift? And if
possible, how to do?
My usual procedure:
1. make a lowpass for the lower frequency edge (sin(x)/x * Blackmann)
2. make a second lowpass for the upper frequency edge (also sin(x)/x *
Blackmann)
3. normalize both lowpasses
4. turn the second lowpass per spektral inversion to a highpass
5. add both passes, this makes a band reject pass
6. turn it into a band pass by spektral inversion
This makes all the taps for a decent FIR-bandpass, it works fine for
even as well as for odd tap numbers, but without any phase shift.
The output is limited to the desired frequency span as requested, so I
hope it should be possible to add a 90 degree phase shift to it (a la
Hilbert)
A decent testbench for the a.m. filter I already have written for
myself, but not yet for a added Hilbert transformation.
so, has anyone a nice idea for this?
kind regards
W.S.
von Wolfgang Kiefer (Guest)
Rate this post
useful
not useful
Iowa Hills Hilbert Filter Designer Ver 2.3 (free)
I hope, this helps.
von W.S. (Guest)
Rate this post
useful
not useful
Sorry, no.
I already know the apps from IOWA.
My intention is rather, to be able to calculate the taps at runtime in
the device. So I need the algorithm raher than the output of a IOWA
filter app.
thanks and
kind regards
W.S.
von derguteweka (Guest)
Rate this post
useful
not useful
Moin,
Maybe this recipe works out for you:
All frequencies between 0..1(=Fsample/2)
Lower Band edge: Fa
Upper Band edge: Fb
Calculate:
 Fshift=(Fa+Fb)/2
 Flp=(Fb-Fa)/2
Design Lowpass filter with Flp as usual. Index of its coefficents goes
from -k...0...+k.
For the Quadrature-BP: Multiply each of its coefficients by
sin(pi*k*Fshift) (for the Inphase-BP: Multiply with cos(pi*k*Fshift))
Gruss
WK
von Christoph Kessler (Guest)
Rate this post
useful
not useful
Octave has an open remez algorithm for hilpert FIR
http://octave.sourceforge.net/signal/function/remez.html
von W.S. (Guest)
Rate this post
useful
not useful
derguteweka wrote:
> Maybe this recipe..
thanks a lot, I will try.
kind regards
W.S.
von W.S. (Guest)
Rate this post
useful
not useful
Carlton F. wrote in post #6841692:
I DO know this app. But: meanwhile I found the solution myself.
Just for your interest:
1. calculate a usual band pass (as I already described) using sin(x)/x -
this gives you a mirror symmetric filter kernel, which does not alter
the phase. Let us call the result Y[0..M-1]
2. calculate the same band pass using (1-cos(x))/x instead of sin(x)/x -
this gives you a point symmetric filter kernel, which shifts the phase
and makes a 90 degree phase shift. Let us call the result Z[0..M-1]
3. assume, each tap is a point in the Y,Z lane. Now you can turn this
point for a angle of your desire according to the known CORDIC
procedure. This gives you (in the Y array) the final kernel with a phase
shift of your choice. The new values in the Z array are not used.
W.S.
von Tobi (Guest)
Rate this post
useful
not useful
but you did not really take all of this 6 years to find the solution,
did you?
I wonder which is the application which require this function?
von -gb- (Guest)
Rate this post
useful
not useful
> Iowa Hills Hilbert Filter Designer, hope it will help
It was just SPAM that and pushed the thread.
von W.S. (Guest)
Rate this post
useful
not useful
When you want to receive SSB transmissions, you need to suppress the
unwanted side band. For this you can use a narrow quartz filter if you
design a analog receiver - but designing a digital receiver you need to
use a I/Q mixer and apply to one of the resulting data streams a
additional 90 degree phase shift - or apply a phase shift of +45 degree
to one stream and a phase shift of -45 degree to the other stream (this
is in short called the phase methode). But it is rather uncomfortable
and a waste of clock cycles to apply a straight delay to one stream and
a 90 degree Hilbert transformation to the other stream, so I decided to
combine the band pass filtering and the phase shift to avoid wasting
precious clock cycles.
That's it.
W.S.
von Anaka (Guest)
Rate this post
useful
not useful
Band stop filter has two pass-bands and separated by a small frequency
called notch frequency where it has zero output.
von W.S. (Guest)
Rate this post
useful
not useful
The problem is solved. Looking back I see, that the solution is easy.
Simply calculate a complex filter, the real component is
mirror-symmeteric and the imaginary component is point-symmetric and
then rotate it using CORDIC or similar. So every phase shift is
possible.
So this thread may be closed.
W.S.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
