EmbDev.net
Forum: ARM programming with GCC/GNU tools ARM Code for color sensor
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Neethu P (Guest)
Rate this post
useful
not useful
Sir,
I am using TCS3200 color sensor. In the data sheet, it is specified that
the output of the mentioned sensor is frequency in the form of square
pulses. How can I find out the frequency value from that output? Anyone
have the code for TCS3200 color sensor with ARM LPC1769? Please help.
von M.K. B. (mkbit)
Rate this post
useful
not useful
You could use a pin which generates an interrupt on each rising edge of
the color sensors signal. When you measure the time between the
interrupts you can calculate the frequency.
von aaaB (Guest)
Rate this post
useful
not useful
Neethu P wrote:
> Sir,
You can connect the pin from the sensor that generates this waveform and
connect it to an Oscilloscope or Logic Analyzer.
von charushilakhandait@gmail.com (Guest)
Rate this post
useful
not useful
aaaB wrote:
> aaaB
can u please share code for tcs3200 colour sensor as i am facing the
same problem........plz
Rate this post
useful
not useful
Neethu P wrote:
> Sir,
von void (Guest)
Rate this post
useful
not useful
charushilakhandait@gmail.com wrote:
> as i am facing the same problem
Uuh, you face the problem that you can't use a search engine with the
terms 'TCS3200 color sensor code' too?
    /*     Arduino Color Sensing Tutorial
     *  by Dejan Nedelkovski, www.HowToMechatronics.com
    #define S0 4
    #define S1 5
    #define S2 6
    #define S3 7
    #define sensorOut 8
    int frequency = 0;
    void setup() {
      pinMode(S0, OUTPUT);
      pinMode(S1, OUTPUT);
      pinMode(S2, OUTPUT);
      pinMode(S3, OUTPUT);
      pinMode(sensorOut, INPUT);
      // Setting frequency-scaling to 20%
      digitalWrite(S0,HIGH);
      digitalWrite(S1,LOW);
23
24
      Serial.begin(9600);
25
26
    void loop() {
27
      // Setting red filtered photodiodes to be read
28
      digitalWrite(S2,LOW);
29
      digitalWrite(S3,LOW);
30
      // Reading the output frequency
31
      frequency = pulseIn(sensorOut, LOW);
32
      // Printing the value on the serial monitor
33
      Serial.print("R= ");//printing name
34
      Serial.print(frequency);//printing RED color frequency
35
      Serial.print("  ");
36
      delay(100);
37
      // Setting Green filtered photodiodes to be read
38
      digitalWrite(S2,HIGH);
39
      digitalWrite(S3,HIGH);
40
41
42
43
      Serial.print("G= ");//printing name
44
45
      Serial.print("  ");
46
      delay(100);
47
      // Setting Blue filtered photodiodes to be read
48
49
50
51
52
53
      Serial.print("B= ");//printing name
54
55
      Serial.println("  ");
56
      delay(100);
57
Code from the first search engine hit:
https://howtomechatronics.com/tutorials/arduino/arduino-color-sensing-tutorial-tcs230-tcs3200-color-sensor/
von Charusila K. (Company: neeri nagpur) (charu)
Rate this post
useful
not useful
I want the same arm code for colour sensor if you have then please
provide me........waiting for the positive response
von void (Guest)
Rate this post
useful
not useful
The above provided code is for ARM Cortex-M3.
It compiles well for ARM Cortex-M3 e.g. Arduino Due board as shown
attached.
If you need code for ARM mbed or LPCXpresso framworks for Cortex-M3 in
LPC1769 you need to port it yourself.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
