EmbDev.net
Forum: ARM programming with GCC/GNU tools STM32 HAL Delay too slow
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Philipp (Guest)
Rate this post
useful
not useful
I recently started with an STM32F103C8T6 on a bluepill board. I am using
SW4STM32 on Windows 10.
When writing a program that blinks an LED on PC13 with the standard
peripheral library and implementing my own SysTick_Handler and Delay
functions, the LED blinks in the correct intervals.
This is the relevant code:
// Main without GPIO Initialization and APB2ENR code
int main(void)
  SystemInit();
  SysTick_Config(SystemCoreClock / 1000);
// My own SysTick_Handler
void SysTick_Handler(void) {
  static uint32_t millis = 0;
  millis++;
  if (millis % 1000 == 0) {
    flipPin();
When I tried porting this code to a project using the Cube HAL libraries
provided by SW4STM32 and using HAL_Delay for delay, the LED blinks ~18x
slower. I tried following other guides on writing HAL applications,
however I could not find any examples about clock configuration.
The relevant HAL code:
int main(void) {
  HAL_Init();
  for (;;) {
    HAL_Delay(1000);
    flipPin();
While the STD code blinks the LED in precise 1000ms intervals, the HAL
code takes ~18000ms for each loop. I have looked at the HAL_Init code,
switched HAL_Init and SysTick_Config and tested flipPin, but could not
find any hints to what might cause this behaviour.
 In case anybody knows what I am doing wrong, please let me know. Thank
you
von Philipp (Guest)
Rate this post
useful
not useful
I can't edit the post, but one important detail: The main function in
STD also has a loop in the form of
for(;;);
von Philipp (Guest)
Rate this post
useful
not useful
Ok, kind of embarassing, I read the code but I skipped the comments. It
says right on line 175 of "stm32f1xx_hal.c":
  /* Use systick as time base source and configure 1ms tick (default clock after Reset is HSI) */
So after configuring the PLL and SysClock with
RCC_PLLInitTypeDef pll;
pll.PLLMUL = RCC_PLL_MUL9;
pll.PLLSource = RCC_PLLSOURCE_HSE;
pll.PLLState = RCC_PLL_ON;
RCC_OscInitTypeDef osc;
osc.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
osc.HSEState = RCC_HSE_ON;
osc.OscillatorType = RCC_OSCILLATORTYPE_HSE;
osc.PLL = pll;
HAL_RCC_OscConfig(&osc);
RCC_ClkInitTypeDef clock;
clock.ClockType = RCC_CLOCKTYPE_SYSCLK;
clock.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
HAL_RCC_ClockConfig(&clock, FLASH_LATENCY_2);
I feel like an idiot, but I will leave this here, so others can find a
solution.
von W.S. (Guest)
Rate this post
useful
not useful
> solution.
Why do you fiddle around with this obfuscating HAL?
Just be a man and build your own firmware. I give you a hint, how to do:
https://www.mikrocontroller.net/attachment/316790/STM32F103C8T6.ZIP
Just have a look into it - and use what you want if you are interested.
btw: the binary in this archive should also work on a blue-pill board.
W.S.
von STM Code Warrior (Guest)
Rate this post
useful
not useful
> you
Perhaps you did not do the clock initializiation in the
HAL version correctly.
von Sebastian E. (Guest)
Rate this post
useful
not useful
SystemCoreClock might still contain the initial clock value (HSI).
Double-check whether the clock configuration updates SystemCoreClock or
call SystemCoreClockUpdate before using SystemCoreClock .
von Heinz M. (subi)
Rate this post
useful
not useful
Try to NOT use HAL_Delay.
With HAL_Delay the µC does nothing, but consume energy. I only use it
for start up, while waiting for some external peripherie to start up.
Never put a HAL_Delay in the Systick or Timer Interrupt!
While HAL_Delay the µC can do nothing else. If the next systick
interrupt comes meanwhile you have a problem. If some other interrupt
comes the HAL_Delay timing is added to the time the other interrupt
takes. Thats why it only should be used while start up or in the main
loop.
Use a timer or the systick and put a counter inside. By 1 ms timer,
count until 1000 and then flip the LED on. Like you have done in your
own systick. Now the µC only needs ~ 1% of the calculating power like
with HAL_Delay. Now you can use different variables to get different
timings out of one timer. With HAL_Delay absolutly not possible.
: Edited by User
von Kala C. (Company: Elxis) (kalacanel)
Rate this post
useful
not useful
Hi...If you really need to disable all interrupts you'd need to poll on
a timer or on CPU cycle counter.
If however you can tolerate SysTick (and possibly other) interrupts you
may want to arrange your interrupt priorities so that instead of
disabling all interrupts with __disable_irq() you disable only the ones
with a priority level lower than a given threshold with __set_BASEPRI().
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
