Java/examples/AdcDemo.java
ADCDemo.java - a NanoVM example
Simple analog digital conversion (ADC) demo. Run this e.g. on the
simple avr atmega8 demo board
import nanovm.avr.*;
class AdcDemo {
public static void main(String[] args) {
System.out.println("Analog digital conversion demo");
// no need to initialize the timer, since 100Hz is default.
// initialize the ADC conversion (there's no default setup for ADC)
Adc.setPrescaler(Adc.DIV64); // slow but accurate conversion
Adc.setReference(Adc.INTERNAL); // use internal reference
// permanently poll ADC channel0
while(true) {
// display internal VBG voltage (about 1.23 volts)
System.out.println("Value VBG: " + Adc.getValue(Adc.CHANNELVBG));
// display internal GND (0 volts)
System.out.println("Value Gnd: " + Adc.getValue(Adc.CHANNELGND));
// display ADC0 value with 10 bits resolution
System.out.println("Value CH0: " + Adc.getValue(Adc.CHANNEL0));
// display ADC0 value with 8 bits resolution
System.out.println("Byte CH0: " + Adc.getByte(Adc.CHANNEL0));
// wait a second for next run
Timer.wait(100);
