EmbDev.net
Forum: ARM programming with GCC/GNU tools Cross-compiling a driver for LM73 sensor for ARM11-based board
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Fight4UrRights (Guest)
Rate this post
useful
not useful
Hi everyone!!
I am working with a board with a ARM11 processor (Freescale i.MX31). I
have successfully cross-compiled the linux kernel 2.6.31 and it's
already running on the board.
In the board I have a LM73 temperature sensor connected via I2C. I
already have the driver for the sensor (i.e. the lm73.c) and all the
header files needed to cross-compile it.
I just wanted to ask if someone could tell me how to cross-compile the
driver so that I can transfer it to the board and then insert it as a
module.
I'm not an experienced linux user. I tried:
root@ubuntu:~/../LM73# "Cross_compiler_path" -o LM73 LM73.c
I get loads of errors that have nothing to do with my code but instead
with header files that call other header files that call...
Maybe I should write a Makefile, which I guess would consist only of a
few simple lines..??
I would appreciate any kind of help.
Thank you in advance.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
