EmbDev.net
Forum: Off Topic Phonelinesoftware
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von ringline (Guest)
Rate this post
useful
not useful
Hi, I am trying to use ModemTest to test two Notebooks using the master
and slave configuration.
Both notebooks connected to Analog phone lines, dialing one another.
I would like to do this without using Phone lines. Can you recommend a
phone Line Simulator product? Or are you aware of any Phone Line
Simulator that works with your software? I know they are expensive.
The Modems I am trying to test are :
Motorola SM56 data Fax Modem (ModemTest Loopback test not working)
Connexant HDAUDIO Soft data Fax Modem with SmartCP(Loopback test works)
Thanks
: Moved by Admin
von Icke (Guest)
Rate this post
useful
not useful
How about to use an older PBX with analogue lines?
von widss (Guest)
Rate this post
useful
not useful
I Dont have a old PBX anymore.
von Icke (Guest)
Rate this post
useful
not useful
www.ebay.com
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
