EmbDev.net
Forum: µC & Digital Electronics LPC2148 I2C I2xSCH timing problem
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Markus29111977 (Guest)
Rate this post
useful
not useful
Im using in my project a LPC2148 controller and have a question
concerning I2C timing. Everything works quite well but when I proofed
the timing of the I2C I discovered that the high time of the clock is
wrong. With I2xSCL/H you can adjust the high and low time (duty cycle)
of the clock. The value says how many clock cycles are used for
high/low. My PCLK runs at 60MHz (I proofed that with a PWM Output, the
frequenzy/duty cycle was exact the expected value). If I set I2xSCL/H to
75 the expected I2C data rate should be 400kHz. In reality it is about
384kHz because the high time of the clock is about 110ns too long
(1.36us instead of 1.25us). The low time fits exactly (1.25us). This
problem occurs on both I2C busses. Do you have any suggestion/experience
on this topic? Thank you for some help.
von Michael M. (Guest)
Rate this post
useful
not useful
how did you measure the on time of your i2c? if it's just been measures
using an logic analyzer, you might miss some slow rising slopes due to
capacitive load on the bus lines.
Rate this post
useful
not useful
Thanks for your answer. I measured the on time with an 100MHz 1GS/s
Oscilloscope. The on time is the time from the beginning of the rising
edge until the beginning of the falling edge. This time is too long.
That means the falling edge should start earlier. There is always the
same time offset of about 110ns (about 7 cycles@60MHz) on the on time
indepent of the value in I2xSCH. So the effect becomes more visible at
higher frequencies. The low time (beginning of falling edge until
beginning of rising edge) fits exactly. To eliminate side effects there
is no slave on the bus (only pullups) and I write a random Byte on the
bus. During this Byte-write I measure the clock timing on the bus.
Rate this post
useful
not useful
I add a screenshot for better understanding.
Settings are:
I21SCLL = 102;
I21SCLH = 48;
So the frequenzy should be 400kHz. But as you see in the picture it is
different.
Rate this post
useful
not useful
could it be that the maximum i2c frequency is limited to ~375kHz when
using 60MHz peripheral clock?
table 143 at page 147 on doc UM10139 would suggest so.
sry, that's all i got...
edit: or maybe not.
there's some errata sheet on the lpc2148 that reads an erroneous
behavior on pulse time generation for the SSP1 module.
maybe, this error occours on the i2c module also and is just not
documented yet.
you could test that by monitoring later pulses after the first 4.
errata sheet:
SSP.1Initial data bits/clocks of the SSP transmission are shorter
than subsequent pulses at higher frequencies
Introduction: The SSP is a Synchronous Serial Port (SSP) controller
capable of operation on a SPI, 4-wire SSI or a Microwire bus. The SSP
can operate at a maximum speed of 30MHz and it referred to as SPI1 in
the device documentation.
Problem:           At high SSP frequencies, it is found that the first
four pulses are shorter than the subsequent pulses.
Work-around: None.
Rate this post
useful
not useful
Thanks for your answer again. I dont´t think that I2C speed on that
controller is limited to 375kHz. At this point the datasheet can be
missunderstood. It says you must ensure that the I2C speed stays within
0 to 400kHz and that each value of I2xSCH/L must be equal or bigger than
4. So I think the 400 kHz refer to fast I2C mode spezification and the
LPC can do faster. I used 2MHz with my BMP085 pressure Sensor without
any problem. Furthermore the problem occurs at all frequencies. During
one Byte transfer all 9 clock pulses are of the same length (but too
long). I wrote to nxp technical support. Maybe they know an answer.
von markus29111977 (Guest)
Rate this post
useful
not useful
Now I got an answer:
"Try with a smaller value for the pull-up resistors. Slow clock edges
cause extended pulse length."
I tried this and it worked. I reduced the pullup resistors from 4k7 to
1k2 and the I2C data rate changed (with the same settings in I2xSCH/L)
from about 384kHz to 396kHz which is very close to 400kHz. I also tried
800 Ohm and got 398kHz. So there is a dependence of the pullup resistor
and the pulse length.
Rate this post
useful
not useful
Finally a picture of the situation with 1k2 pullups. Compare to the
picture above with 4k7 pullups (all settings in the LPC are the same).
von Question (Guest)
Rate this post
useful
not useful
What values did you use for 2 MHZ?
Thanks
Rate this post
useful
not useful
The maximum I can do with 2.1 K pullup resistors is about 1.6MHZ.
I have to decrease the bus capacitance and also the pull ups.
Thanks
Rate this post
useful
not useful
Got it to 2.146 MHz!!! with same 2.1K pull ups!!!
von yerraji (Guest)
Rate this post
useful
not useful
i'm facing problem with i2c1 in lpc2148. i'm connected the sensor to the
i2c0 it's working fine, but with the connection same code but changed
the registers instead of the i2c0 replaced the the i2c1. then it's
giving 0xF8 at start bit it means no connection like...
and also another thing i did just added pull up resistors even at the
time also not worked. it cleared the start bit problem and after that
another problem is sending the slave address there ack, and also it's
giving an error that's regarding bus error.
please............. give me better solution for this almost i worked on
2 weeks even there is no small change.
von ChangeBloodElf (Guest)
Rate this post
useful
not useful
At this point the datasheet can be missunderstood. It says you must
ensure that the I2C speed stays within 0 to 400kHz and that each value
of I2xSCH/L must be equal or bigger than 4.
LPC can do faster. I used 2MHz with https://www.mywegmansconnect.one my
von Jonsrnangerang J. (Company: NO) (jonsrnangerang420)
Rate this post
useful
not useful
indepent of the value https://walmartone.tech/walmart-one-wire/
von Ashish K. (ashishkumarji)
Rate this post
useful
not useful
von Rembo R. (Company: adbesds) (remboroy)
Rate this post
useful
not useful
> LPC can do faster. I used 2MHz with https://allaboutwegmans.jimdosite.com my
 I2C bus is a Byte Oriented bus. Only a byte can be transferred at a
time. Communication(Write to & Read from) is always initiated by a
Master.
Thanks
von Nash D. (Company: Webcorewin) (nbaever3)
Rate this post
useful
not useful
I added more information above. Another board works all the time, this
one works for around 10 or so read/writes and then the micro throws a
bus error interrupt. Pull-ups are 4.75k to 3.3 V.It looks like from the
scope shot that SDA went low a little too soon but it's hard to tell how
much time difference there may be from the image, and the clock low
period after that looks shorter than others. Not sure about the clock,
maybe it's within tolerance, but the SDA going low could qualify as a
start condition (at a time when it may not be valid). You might try
comparing the equivalent waveforms from the working board to this one to
see if it's also having marginal timing but just happens to work.
Rate this post
useful
not useful
bus error interrupt.   https://myfiosgateway.one
https://spicemoneylogin.in
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
