EmbDev.net
Forum: µC & Digital Electronics Example program for ISP in AT89C51CC03
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Shaik P. (shaik)
Rate this post
useful
not useful
hallo all,
I am working with AT89C51CC03.
I have install
-> Flip 2.4.6
-> KeiluVision4
-> Hyperterminal (In built in Window XP)
I have also all example files from www.atmel.com
I had connect AT89C51CC03 to my PC n trying to communicate with RS232
using ISP (In System Programming).
Any one have sample program for this...??
Is it need to install another s/w..??
how can i write program (in ´C´ language)..??
thank u in advance.
von Ralf (Guest)
Rate this post
useful
not useful
??? Why do you need a sample program for programming your device? Or do
you mean something like the good old "Hello World" program?
No, for device programming the FLIP software (and proper wired hardware)
should be enough.
As you wrote above, you're using Keil. So what's the problem? There
should be a example folder.
Regards,
Ralf
von shaik (Guest)
Rate this post
useful
not useful
hallo Ralf,
Thank u for ur answer
n sorry for my questions.
von shaik (Guest)
Rate this post
useful
not useful
hallo Ralf,
Ya i have all Software n also Keil Example folder.
I know how to use that all softwares and no need of another Software.
when i try the example project in Keil than error is "Target not
created"
The target is Simulator. I search simulator on net but i will not find
that.
I don´t know abt other tagets. I just wanna see output of any one
program.
I already try to run 3 sample programs of Keil.
ya, i want the program like "Hello World". this same program is in Keil
example folder, but i can´t able to see the printed output like "Hello
World".
I also try sample programs on Flip and one can see the output in
Hyperterminal. I try but i will not able to see the output.
I am trying to do ISP(In System Programming) with RS232 in AT89C51CC03.
I have to make one program in which i give Analog Signal with Pot (in
AT89C51CC03) as input and take PWM signal as output.
I read almost all datasheet for this softwares and for AT89C51CC03.
I connect AT89C51CC03 controller to PC and i saw that the data send or
receive through RS232, while the RX(Red) and TX(Green) blinking when i
run program in FLIP, but i can´t see the output.
I know 'C' Programming, but i am new in Embedded system.
If u have any sample program related to my project requirment then reply
me.
If u have any advice then also reply me.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
