EmbDev.net
Forum: µC & Digital Electronics Problem Interfacing ADC AD7856 with LPC2148
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Joydeep S. (joydeep_s)
Rate this post
useful
not useful
Hello
I am trying to interface external ADC AD7856 with LPC2148. Here goes my
code
int main(void)
  U16 adc_val = 0;
  U8 data = 0;
  U8 upper = 0, lower = 0;
  HardwareInit();     //SPI and ADC initialised
  AD_7856_SYNC_SET(); // SYNC bit set high
  while(1)
   while((AD_7856_BUSY_IOPIN & AD_7856_BUSY));//wait for BUSY bit to set 0
    AD_7856_SYNC_CLR();         // SYNC bit high
    delay(3);
    data = 0xE0;                //Upper MSB write
    SPI_Write(1, &data);
    data = 0xC0;                //lower LSB write
    delay(3);
    AD_7856_SYNC_SET();
    delay(3);
23
24
25
   AD_7856_SYNC_CLR();
26
   delay(3);
27
   SPI_Read(&upper);          //Upper MSB read
28
   adc_val = upper <<8;
29
   SPI_Read(&lower);          //Lower LSB read
30
    adc_val = adc_val | lower;
31
    AD_7856_SYNC_SET();
32
33
  return 1;
34
According to the data I can writing I should read back the data as
0x20C0 but instead the output is always Garbage values.
Moreover the Busy  bit never sets high during conversion it always
remains low.
Any suggestion is most welcome. And any change in the code required???
Joydeep
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
