EmbDev.net
Forum: PCB Design & Technology How to get automatic labels on board
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Alex (Guest)
Rate this post
useful
not useful
Is it possible to get labels to be added (to some predefined layer) for
pins (or traces) in a board (Eagle 4.16 or Eagle 5.x) in an automatic
way (say show all labels) ?
Thanks!
: Moved by Moderator
von Michael H. (michael_h45)
Rate this post
useful
not useful
Not with any built-in function, nor will that be possible to do while
routing that trace.
Yet you can enable displaying pin-numbers in the board view by checking
"display pad names" in options -> set -> misc.
Or you can write your own ulp to place text-elements onto the track. but
as stated, this will be static only. So the labels wont change/move with
changing the trace without re-running the ulp.
von Arifa A. (Company: rush pcb) (arifa_anees)
Rate this post
useful
not useful
http://www.ehso.com/PCB_label.htm
take help from above mentioned link
courtesy by: www.rushpcb.com
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
