EmbDev.net
Forum: ARM programming with GCC/GNU tools H-JTAG Error: Can't halt target
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Amit C. (amit_c)
Rate this post
useful
not useful
Hi All,
Recently I build a wiggler clone with reference attached
schematic(jtagwigglersch.jpg).
I using my own lpc2148 development kit, I tried to debug my board with
H-JTAG.
It is really surprising for me that I'm able to detect the device(please
see Connection.jpg) but while debugging the code I using the check
option in H-Flasher to verify the connection. It is giving me error:
Cant halt target and make it enter debug.
If anybody have faced this kind of problem share the solution for this.
Thanks,
Amit C
von mthomas (Guest)
Rate this post
useful
not useful
IRC the TRST-line is needed too for this controller - (S)RST might not
be enough.
Rate this post
useful
not useful
Thank you Martin,
I Connected a nTRST signal and its working perfectly.
Thanks,
Amit C
von amir (Guest)
Rate this post
useful
not useful
Hi amit c
i had that problem like you.could you share new programer's schematic?
tnx
von Amit C (Guest)
Rate this post
useful
not useful
Hello,
I don't have tool to draw a schematic, but I'll explain the changes.
1. Connect the 6th no pin of parallel port to 9 no pin of 74xx244.
2. Connect 11 no pin of 74xx244 to the 3rd no pin of jtag header.
3. And 18 no pin of 74xx244 to ground.
Thanks
Amit
von Deniz (Guest)
Rate this post
useful
not useful
How can i solve this problem i have
von s .vrao (Guest)
Rate this post
useful
not useful
hi frinds
i have a problem with above circuit when i am using this circuit for
lpc1768 the h-jtag server was not connecting.it was showing the massage
unable to load h-jtag lpt driver. only usb modem is supported.please
help me ....
Rate this post
useful
not useful
Hello s .vrao,
Hope you have selected lpt port for programming in settings.
Please confirm if not.
Thanks
Amit C
von Redus (Guest)
Rate this post
useful
not useful
Not 18 ... but 19
von Redus (Guest)
Rate this post
useful
not useful
Redus wrote:
> but
Not 18 but 19
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
