EmbDev.net
Forum: PCB Design & Technology PCB for High Power LEDs
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Ersin O. (Company: BARAN) (baran-tech)
Rate this post
useful
not useful
Hello,
I have developed a high power UV-LED Array. Total loss of the PCB is
about 200 Watts. The PCB is made from Aluminum and installed on a big
heat-sink. The heat-sink is cooled with a high power FAN.
Unfortunately I can't cool down enough with the aluminum PCB. It can't
transfer enough heat. I thought about using a ceramic PCB. Does anyone
have experience with ceramic PCBs?
How are they attached to the heat-sink? Can I use screws?
Which type of thermal material is used between the PCB and the
heat-sink?
Another question: Is there a way to manufacture an aluminum PCB directly
on a heat-sink?
Regards,
Ersin
von hdd (Guest)
Rate this post
useful
not useful
Have you thought about using a petier element between the PCB and the
heat-sink for a better heat transfer?
Rate this post
useful
not useful
I didn't think about it since the current consumption will be too high.
von Fasti (Guest)
Rate this post
useful
not useful
Hello,
I don't think that a ceramic PCB will perform better. A Copperinlay
might be the better way of coping with these high losses. You didn't
tell us how big your PCB is.
regards
Fasti
Rate this post
useful
not useful
Hello Fasti,
The PCB is 60x45 mm. However I can change its dimensions.
Attached is the MCPCB for 6 LEDs in PDF.
Thanks,
Ersin
von Carlos84 (Guest)
Rate this post
useful
not useful
Hi Ersin,
i know some cool experts for cooling.
please send me an email at
carlosde84 @ yahoo . com
as i am right your company is in krefeld. this is
40 km away from them.
regards
carlos
von Tim (Guest)
Rate this post
useful
not useful
> Total loss of the PCB is about 200 Watts.
This ist not a cooling Problem.
Its obviously a design failure.
von water (Guest)
Rate this post
useful
not useful
Use water cooling- anything else will fail.
von Falk (Guest)
Rate this post
useful
not useful
@  Tim (Guest)
Why? A Pentium CPU did/does dissipate around 100W over an area of
roughly 10x10mm, cooled with a reasonable big heatsink and a fan.
For ceramic pcbs/heatsinks, look here
http://www.ceramtec.de/ceramcool/
Solder
> Can I use screws?
Nope.
>heat-sink?
Copper. There is no PCB anymore, just the isolating ceramic, copper
layer, device.
Good luck.
von Michael D. (Guest)
Rate this post
useful
not useful
Why is the loss that high?
Is it only the LED's that create this heat or is there sonething like
resitors, converters?
If it's only the LED`s I would be interessed how many of wich LED's you
are using.
Rate this post
useful
not useful
Thank you very much for your answers.
@water: We will design also water-cooled version of the lamp. But an
air-cooled version is also required.
@Michael D.: Only LEDs are creating heat. I use 6x LZC UV Leds from
company Ledengin. The next version will be 12 LEDs.
@Falk: Thanks. The idea with copper directly on ceramic heat-sink looks
perfect. I will contact ceramtec tomorrow.
von Tim (Guest)
Rate this post
useful
not useful
> roughly 10x10mm
Thats right but a Pentium CPU integrates 3 Mio. of Transistors.
The PCB of the TS holds only 6 LEDs and loses 200W. Thats clearly a
design error.
von Maddin (Guest)
Rate this post
useful
not useful
Maybe you should get in contact with Häusermann in Austria, they are
specialized on this kind of PCBs.
http://www.haeusermann.at/2,product/22,HSMtec/35,LED-Lighting---Intelligente-Leiterplatten-fuer-innovative-Anwendungen-
Best regards,
Martin
von A6AA (Guest)
Rate this post
useful
not useful
Hello Tim,
>design error.
The LEDs mentioned here are most likely multi-die LEDs i.e. there are
for example 10x10 dies on a ceramic interposer. The dies itself are high
power dies. This means the design uses 600 LEDs. That's roughly
1800V*LED. With 100W that's roughly 50mA per LED which ist not foo far
out for high power LEDs. The only problem in such a desigh as
highlighted by the TO is the heat in a small space. And if you think
back to the Pentium: The Pentium of nowadays has an intelligent
heat/Voltage management to reduce power consumption. You get your old PC
(e.g. Celeron) a high perfonace task and the fan will spin up to
decrease the Rth in order to get the heat away from the device. I'd
guess that would be a nice feature :) for a lamp: you switch it on and
as the lamp gets warmer a fan will start to enligthen the surrounding by
its roaring noise :)
rgds
von Reinhard Kern (Guest)
Rate this post
useful
not useful
did you ever work with a conventionel 500 Watt movie lamp? You would
want to have a fan to cool it.
I am sure Ersin does not use a 100W output UV light sitting at his tv.
This would be hazardous for his health.
Reinhard
von Jay Hughes (Guest)
Rate this post
useful
not useful
Our company manufactures many LED torch/flashlight designs for the
Non-Aligned Military market.
We typically use arrays of 10W LEDs, some are 140cm diameter with 40 x
10W LEDs, particularly in our drone bomb diverters. These units heat
dissipation is way beyond alumim(i)um PCB capabilities.
Our PCBs are FR4 with holes sufficiently large for the rear ends of the
LEDs to protrude into. Note: The use of LEDs with isolated heat
dissipaters is required.
The heatsinks are thick alumin(i)um plates (5-15mm).
When the light assemblies are fabricated, generous dollops of heat
conducting paste is applied to each exposed LED heatsink and when the
faceplate - with the LEDs - is assembled to the alumin(i)um heatsink and
secured with screws (mounting screws have to be distributed around the
outer edge as well as in the central area) good thermal conductivity can
be achieved.
Many of our IR 'illuminators' (as the military call them) have a
sighting Laser unit in the centre position.
Where the application requires addition cooling, we simply add a
computer CPU fan assembly to the rear of the thick heat sink.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
