EmbDev.net
Forum: FPGA, VHDL & Verilog ADC -FPGA interfacing
von niharika g. (neha0590)
Rate this post
useful
not useful
I am using actel FPGA and 12bit parallel adc adc12010 from ti. As a
beginner I want to write a code for following-
"I will give a ramp voltage of 0-2V to ADC. crystal clock is 50MHz, I am
converting it to 100KHz for ADC. I want FPGA to generate pules till ramp
is less than 1. as ramp reaches 1 no pulses should be produced.  For
this I have written following code. (d0 - d11 are I/O pins of FPGA
conected at ADC input.) ADC is always enable. I am storing adc output in
a 12bit variable store.
During synthesis I get the warning which says incomplete sensitivity
list and input ports(d0,d1..) are unused. Also after place & route it is
not showing d0,d1.. as I/O ports (so as to assign the actual pin nos
coresponding to FPGA) . Kindly help me
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
use IEEE.NUMERIC_STD.ALL;
entity adc is
port ( clk,d0,d1:  in std_logic ;
        d2, d3: in std_logic ;
        d5, d6: in std_logic ;
        d7, d8: in std_logic ;
        d9: in std_logic ;
        d10: in std_logic ;
        d11: in std_logic ;
        d4:in std_logic ;
        adc_clk, pulse :out std_logic );
end adc;
architecture behav of adc is
signal count1 : integer range 0 to 500:=1 ;
signal clk1 : std_logic ;
signal O : std_logic ;
begin
process(clk)
begin
if rising_edge(clk) then              -- start for 100khz clk1 for adc
    if (count1<250) then
        clk1 <= '1';
        count1<= count1+1;
    elsif (count1>=250 and count1<500) then
        clk1<='0';
        count1 <= count1+ 1;
    elsif (count1=500) then
        clk1<='1';
        count1<=1;
    end if;
end if;
end process;  -- end process for 100khz clk1
    process (clk1)
variable store: std_logic_vector(11 downto 0);
begin
store(0)  := d0;
store(1)  := d1;
store(2)  := d2;
store(3)  := d3;
store(4)  := d4;
store(5)  := d5;
store(6)  := d6;
store(7)  := d7;
store(8)  := d8;
store(9)  := d9;
store(10) := d10;
store(11) := d11;
        if (clk1 = '1' and clk1'event) then
            if (store(11 downto 0) < "010011011001" and store(11 downto
0)> "100000000000") then
                O <= clk1;
            else
                O <= '0';
            end if;
        end if;
    end process;
adc_clk <= clk1;
pulse <= O;
end behav;
von Duke Scarring (Guest)
Rate this post
useful
not useful
Keep your library list compact. Don't use the obsolete synopsys
packages!
--use IEEE.std_logic_unsigned.all;
--use IEEE.std_logic_arith.all;
And can you post your testbench?
A simulation can show most of design errors.
Duke
von bko (Guest)
Rate this post
useful
not useful
this cannot be true with  std_logic_vector or ?
>  and store(11 downto 0)> "100000000000") then
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
I assume it should be an or...
Additionally the way shown is not a good way to generate a "new" clock.
Indeed its a very, very poor way. Usually a beginner VHDL design should
have exactly 1 clock. Derived timings are done by clock enables...
von arunkumar (Guest)
Rate this post
useful
not useful
i attached a simulation output snap! how you give 12-bit input value! If
the input is voltage means how you convert voltage into 12-bit digital
value!!
Rate this post
useful
not useful
Why do you hijack someone others over 2 years old thread?
Create a new one for a new question!
von global internet avisor (Guest)
Rate this post
useful
not useful
@Mr Miller: Why do you not simple moove his question to a new thread,
since you are a moderator?
von edward (Guest)
Rate this post
useful
not useful
signal count1: STD_LOGIC_VECTOR(9 downto 0);
signal clk1 : std_logic;
if(conv_integer(coun1)<250) then
elseif(conv_integer(coun1)<500) then
elseif(conv_integer(coun1)=500) then
count1 <="111111111111"
von edward (Guest)
Rate this post
useful
not useful
signal count1: STD_LOGIC_VECTOR(11 downto 0);
von roy (Guest)
Rate this post
useful
not useful
can i get a vhdl code for ad7608 interfacing .
Rate this post
useful
not useful
No more comment...
How much do you pay?
If it is for homework lets try it the ohter way: you start with
something, you show it and you report the problems you encountered and
we try to help you.
But if you do so: start a new thread for your new problem...
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
Loading...
