EmbDev.net
Forum: FPGA, VHDL & Verilog ad7896 vhdl interfacing
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von etai (Guest)
Rate this post
useful
not useful
Hello,
I need help writing code to interface and synchronize with component
AD7896, by the first time diagram shown data sheet of the component
(mode 1).
I'd be happy if you can write me sync interface or give some tips on how
to start writing the module
50MHz input clock frequency. (If necessary, I'll build some of the
frequency, but I need to know what module working frequency).
Data Sheet:
http://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCEQFjAA&url=http%3A%2F%2Fwww.me.psu.edu%2Fsommer%2Fme445%2FAD7896.pdf&ei=yZuTUIX4FsjX0QX_94DwDQ&usg=AFQjCNEP9OIxe3ikFs1gvtE-j49XsfdtvA
I need to make the information bit parallel output to use another module
Thank you helpers!!
von Tim (Guest)
Rate this post
useful
not useful
My tip is to start with the entity.
von P. K. (pek)
Rate this post
useful
not useful
Looks to me similar to an SPI-interface ("busy" could be interpretated
as something like CSN). Why not start with an SPI (you'll find plenty of
them in the web).
von etai (Guest)
Rate this post
useful
not useful
this is the module that i wrote, but it is not working:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity TRQ is
  port(
    clk: in std_logic; --8.33MHz
    clk_gen: in std_logic; --50MHz
    rst: in std_logic;
    serial_data: in std_logic;
    busy: in std_logic;
    sclk: out std_logic; --clk for the A/D
    convst: out std_logic; --starting the conversion
    parallel_data_out: out std_logic_vector(11 downto 0):="000000000000"
end TRQ;
architecture ARC_TRQ of TRQ is
  signal data_save: std_logic_vector(10 downto 0) :="00000000000";
--save the data to get out synchronous
  signal temp_sig: std_logic_vector(4 downto 0); --save the first 4 bits
of data
  signal cnt_data: integer range 0 to 15 :=0; --counter of the data bits
  signal state: integer range 0 to 2 :=0; --conversion states: 2- delay
before next conversion 1-convert , 0- reading data bits
  signal busy_delay: integer range 0 to 67 :=0; --delay until busy
rising edge
  signal delay_state: integer range 0 to 4 :=0; --delay 400ns before the
next conversion
  signal clk_cnt: integer range 0 to 5 :=0; --counter for sclk generator
  signal sclk_en: std_logic :='0';  --enable sclk
  signal sclk_sig: std_logic :='0'; --signal for sclk generator
begin
  process(clk,rst)
  begin
    if rst='0' then
      convst <= '1';
      parallel_data_out <="000000000000";
      data_save <= "00000000000";
      cnt_data <= 0;
      state <= 0;
    elsif rising_edge(clk) then
      case state is
        when 0 => -- conversion state
          sclk_en <= '0';
          if busy='0' then
            convst <= '0';
            if busy_delay = 67 then
              busy_delay <= 0;
              state <= 1;
            elsif busy_delay = 1 then  --
              convst <= '1';       --
            else
              busy_delay <= busy_delay+1;
            end if;
          else
            state <= 0;
          end if;
        when 1 =>  -- reading data bits state
          if busy = '0' then
          sclk_en <= '1';
          case cnt_data is
            when 0 =>
              temp_sig(0) <= serial_data;
              cnt_data <= cnt_data+1;
            when 1 =>
              temp_sig(1) <= serial_data;
            when 2 =>
              temp_sig(2) <= serial_data;
            when 3 =>
              temp_sig(3) <= serial_data;
            when 4 =>
              data_save(0) <= serial_data;
            when 5 =>
              data_save(1) <= serial_data;
            when 6 =>
              data_save(2) <= serial_data;
            when 7 =>
              data_save(3) <= serial_data;
            when 8 =>
              data_save(4) <= serial_data;
            when 9 =>
              data_save(5) <= serial_data;
            when 10 =>
              data_save(6) <= serial_data;
            when 11 =>
              data_save(7) <= serial_data;
            when 12 =>
              data_save(8) <= serial_data;
            when 13 =>
              data_save(9) <= serial_data;
            when 14 =>
              data_save(10) <= serial_data;
            when 15=>
              parallel_data_out <= serial_data & data_save(10 downto 0);
              cnt_data <= 0;
              state <= 2;
          end case;
        else
          state <= 1;
        end if;
        when 2 => -- waiting 400ns before next conversion
          sclk_en <= '0';
          if delay_state = 4 then     ----------
            state <= 0;
            delay_state <= 0;
          else
            delay_state <= delay_state+1;
          end if;
      end case;
    end if;
  end process;
  process  (rst,clk_gen)
  begin
    if rst='0' then
      sclk_sig <= '0';
      clk_cnt <= 0;
    elsif rising_edge(clk_gen) then
      case clk_cnt is
        when 0 =>
          sclk_sig <= '0';
          clk_cnt <= clk_cnt+1;
        when 3 =>
          sclk_sig <= '1';
        when 5 =>
          sclk_sig <= sclk_sig;
          clk_cnt <= 0;
        when others =>
      end case;
    end if;
end process;
sclk <= sclk_sig when sclk_en = '1' else '0';
end ARC_TRQ;
may i have mistakes??
and Peter K. i did not understand you..
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
