EmbDev.net
Forum: µC & Digital Electronics Atomic write - STM32
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lasse S. (cowz)
Rate this post
useful
not useful
I'm currently working with a STM32F4 and try to implement atomic access
to variables (e.g. mutexes).
Currently, I disable all interrupts before accessing a mutex, and enable
them afterwards.
Now there exist the LDREX and STREX commands on the STM32, which seem to
be perfect for my application. But how do I use them correctly? In the
manual it says that an STREX must have the same address as the
previous LDREX. So I still need to disable interrupts (or atleast the
scheduling), as in another task I might have another LDREX/STREX
combination.
Is there any other way for read/check/write operations? Mutexes are only
one of my concerns, another is:
- i have a list of integers, which are all set to zero
- i want to set one of those entries to 1 (==this entry is busy, don't
use it)
- do some calculations and in the end set that same entry to another
value (>1)
This should be working with scheduling and interrupts (both tasks and
interrupts access this list, therefore waiting for mutexes is not
possible).
Also disabling the interrupts is bad, as I actually don't want my
processes to have the rights to do that.
I hope you can help me, or point out that I'm just not seeing the easy
possibility.
Yours
Lasse
von Fritz (Guest)
Rate this post
useful
not useful
You should read the The Cortex-M4 Instruction Set Manual carefully. You
get a resultvalue aftera LDREX/STREX pair. The STREX only executes if
there was no other LDREX/STREX beetween by an other interrupt. You have
to repeat the LDREX/STREX pair. There is also an example in the manual.
Not to allow a process or task to enable or disable the interrupts is a
good idea, but you should also not allow LDREX/STREX in a process or
task, this are typically system interna. Usually a RTOS handles this in
special system calls!
You can change a list of integer in the following way:
Examples
MOV  R1, #0x1 ; Initialize the ‘lock taken’ value
try
LDREX  R0, [LockAddr] ; Load the lock value
CMP  R0, #0 ; Is the lock free?
ITT     EQ  ; IT instruction for STREXEQ and CMPEQ
STREXEQ R0, R1, [LockAddr] ; Try and claim the lock
CMPEQ  R0, #0 ; Did this succeed?
BNE  try ; No – try again
.... ; Yes – we have the lock.
now change the list save because no other task can acess it.
MOV  R1, #0x1
STR  R1, [LockAddr]; now the list is free for other taks to use.
Every task that want to use the list must use the above locking
mechanism, then there you have exclusive access to the list.
Hope this helps.
von Lasse S. (cowz)
Rate this post
useful
not useful
Thank you for your answer. I did not find the part about the behaviour
if interrupted.
Why should I limit (and how?) the processes allowance to use
LDREX/STREX? They don't seem to be able to mess with the system.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
