EmbDev.net
Forum: PCB Design & Technology Altium (SVN)DbLib Add/Edit Component in Altium
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Martin (Guest)
Rate this post
useful
not useful
Hello!
I'm testing the SVNDbLib feature of Altium Designer 14.1.
The database resides on a MySQL-Server and the symbols/footprints are in
a SVN repository.
The only problem i have is that Add/Edit/Delete Component are not
available in the Table Browser context menu (as like here:
http://techdocs.altium.com/display/ADOH/Working+with+Version-Controlled+Database+Libraries#WorkingwithVersion-ControlledDatabaseLibraries-ModifyingaDatabaseTablethroughtheSVNDBLibFile
Thus it seems i have to use an external program to edit components in
the database, which seems a bit of an overkill to teach a designer if he
just wants to copy a resistor to get a new value.
Everything is set up according to the instructions found here:
http://techdocs.altium.com/display/ADOH/Using+Components+Directly+from+Your+Company+Database
and the document linked above.
Everything else is up and running, i can place parts, and editing of
symbols and footprints from the Table Browser in the SVNDbLib-Editor
works, as well as updating them with the Storage Manager.
I also tested this with an xls-file for the database using a DbLib and a
SVNDbLib.
Any comments are higly appreciated!
Martin
von Martin (Guest)
Rate this post
useful
not useful
If anybody is experiencing the same problem:
Editing the database in Altium's Table Browser is only available with an
Access-Database. Connections to other databases are read-only.
von Christian B. (luckyfu)
Rate this post
useful
not useful
There is another Issue: even with an access db Library is only editing
of former existent parts available. But it's impossible (testet witch
AD10 + AD13) to add a new component. For this it's needed to do it in MS
Access.
von Timofonic T. (timofonic_t)
Rate this post
useful
not useful
Are new versions better than this?
von HolgerKraehe (Guest)
Rate this post
useful
not useful
Hi
We have also an setup with a MySQL Database in the background.
It is correct, that you cannot edit/remove/add components within altium
itself.
We have created an own Website for these things.
On this site, we can add/remove/edit all components and we have an
integrated wizard which guides you through the process of the component
creation.
von Saimen S. (Company: Tianweisheng) (saimenshen)
Rate this post
useful
not useful
Hi There ,
Glad to contact with you , Here is Saimen in Tianweisheng , wish we will
have a good cooperation in the furture if we have the honor .
Our company is one of the largest custom-made PCB manufacturer in China.
We can OEM,ODM,EMS single side,double side,multilayers and aluminum pcb,
FPC board in
different finishing,with high quality and competitive price.
a.Short lead time.
b.Reply and delivery in time.
c.Contact with us at any time.
d.Good after service.
e.Quality check several times before shipment.
Once I receive your reply, I will send our best price for you as soon as
possible.
Thank you very much, waiting for your kindly reply.
Have a nice day
Sincerely ,
Saimen
Shenzhen Tianweisheng Electronic Co., Ltd
Tel:(+86)-0755 2908 7997
whatsapp :(+86)13418454254
Skype: saimen@twspcb.com
E-mail: saimen@twspcb.com
Address:Gongle, Xixiang, Baoan District
Website:twspcb.en.alibaba.com
        www.twspcb.cn
von Fred (Guest)
Rate this post
useful
not useful
I am trying to set up the SVNDBlib & I have somes problems
1- I am not able to manage multiple user to my database (MDB)
2- The SVNDBLib is linked to my projet
3- I am not able to have the source control on th DB itself.
If you have more information & hints, I would really appreciate it.
If you have information on setuping a SQL server for the DB PArts.
Thanks!
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
