EmbDev.net
Forum: µC & Digital Electronics Problem with atmega -8
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Ajay R. (ajay_r)
Rate this post
useful
not useful
Hey..I am trying my hands on lcd 16x2 and somehow i got it to work.I'm
trying to display an output on 16x2 which is dependent on sum input on
other pins but cant get it to work.Here is my code..
 #define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
#define LCD_DATA PORTB                //LCD data port
#define ctrl PORTD
#define en PD2                         // enable signal
#define rw PD1                       // read/write signal
#define rs PD0                     // register select signal
int main()
DDRB=0xff;                                  // setting the port B
DDRD=0x07;                                // setting for port D
DDRC=0;
PORTC=0b0000000;
init_LCD();                                 // initialization of LCD
_delay_ms(50);                        // delay of 50 mili seconds
23
LCD_write_string("“hello world”");                      // function to print string on LCD
24
if(PINC==0b0000001){
25
_delay_ms(50);
26
LCD_cmd(0xc0);
27
_delay_ms(1);
28
LCD_write_string("THIS IS WORKING ");}
29
return 0;
30
31
32
void init_LCD(void)
33
34
LCD_cmd(0x38);                            // initialization of 16X2 LCD in 8bit mode
35
_delay_ms(1);
36
LCD_cmd(0x01);                                 // clear LCD
37
_delay_ms(1);
38
LCD_cmd(0x0E);                        // cursor ON
39
_delay_ms(1);
40
LCD_cmd(0x80);                     // —8 go to first line and –0 is for 0th position
41
_delay_ms(1);
42
return;
43
44
45
void LCD_cmd(unsigned char cmd)
46
47
LCD_DATA=cmd;
48
ctrl =(0<<rs)|(0<<rw)|(1<<en);
49
_delay_ms(1);
50
ctrl =(0<<rs)|(0<<rw)|(0<<en);
51
_delay_ms(50);
52
return;
53
54
55
void LCD_write(unsigned char data)
56
57
LCD_DATA= data;
58
ctrl = (1<<rs)|(0<<rw)|(1<<en);
59
_delay_ms(1);
60
ctrl = (1<<rs)|(0<<rw)|(0<<en);
61
_delay_ms(50);
62
return ;
63
64
65
void LCD_write_string(unsigned char *str)             //store address value of the string in pointer *str
66
67
int i=0;
68
while(str[i]!='\0')                               // loop will go on till the NULL character in the string
69
70
LCD_write(str[i]);                            // sending data on LCD byte by byte
71
i++;
72
73
return;
74
The first line ie HELLO WORLD is working fine but there is no display in
the second line.
von Ralf (Guest)
Rate this post
useful
not useful
> _delay_ms(50);
> LCD_cmd(0xc0);
> _delay_ms(1);
The program doesn't wait for PINC -> 1
Rate this post
useful
not useful
Ralf wrote:
>> _delay_ms(50);
>> LCD_cmd(0xc0);
>> _delay_ms(1);
I didnt get can you elaborate a bit please.
von sepp1985 (Guest)
Rate this post
useful
not useful
#include <avr/io.h>
#define ctrl PORTD
int main()
DDRC=0;
PORTC=0b0000001;  //Sink mode???
23
24
25
while(1) //do it ever and ever and ever
26
27
28
_delay_ms(50);
29
LCD_cmd(0xc0);
30
_delay_ms(1);
31
32
33
return 0;
34
35
36
void init_LCD(void)
37
38
39
_delay_ms(1);
40
41
_delay_ms(1);
42
43
_delay_ms(1);
44
45
_delay_ms(1);
46
return;
47
48
49
50
51
LCD_DATA=cmd;
52
53
_delay_ms(1);
54
55
_delay_ms(50);
56
return;
57
58
59
60
61
LCD_DATA= data;
62
63
_delay_ms(1);
64
65
_delay_ms(50);
66
return ;
67
68
69
70
71
int i=0;
72
73
74
75
i++;
76
77
return;
78
: Edited by Admin
von Route_66 (Guest)
Rate this post
useful
not useful
What is connected to PORT C, especialli at bit 0 of it?
Rate this post
useful
not useful
sorry, bit 1 of port C.
von B.A. (Guest)
Rate this post
useful
not useful
This linie is possiply wrong.
You want to do something if PC0 (Pin0 from Port C) is high?
try this:
if(PINC & 0b0000001){
Rate this post
useful
not useful
Route_66 wrote:
> sorry, bit 0 of port C.
Rate this post
useful
not useful
just a constant voltage source. I was trying to test thats why
Rate this post
useful
not useful
I tried this code and it worked fine for a simple led
 #include <avr/io.h>
int main(void) {
DDRB=0;
DDRC=0b11111111;
PORTC=0b00000000;
PORTB=0b00000000;
if(PINB==0b00000001)
{PORTC=0b11111111;}
return 0;
but when i interchanged PORTC AND PORTB ie interchanged their function
it didnt worked.So i guess there in something wrong with input pins at
PORTC.By the way im using proteus for simulating
von Ralf (Guest)
Rate this post
useful
not useful
> _delay_ms(50);
> LCD_cmd(0xc0);
> _delay_ms(1);
thereabouts.
But what changes the bit? I think, you would better wait (e.g. if it is
a button)
von Ralf (Guest)
Rate this post
useful
not useful
Sorry, to slow.
Rate this post
useful
not useful
>> _delay_ms(50);
>> LCD_cmd(0xc0);
>> _delay_ms(1);
> thereabouts.
> a button)
I understand what you are saying but im not using a switch pinc is
connected to vcc from the beginning no switch is there
von B.A. (Guest)
Rate this post
useful
not useful
PC0 = high
PC1 ... PC7 = low
Do you have connect the other Pins (Pin 1 to Pin 7) from Port C to
Ground?
Rate this post
useful
not useful
> PC0 = high
> PC1 ... PC7 = low
> Ground?
Yes...Done that
Rate this post
useful
not useful
TAKE A LOOK AT THIS
 #include <avr/io.h>
int main(void) {
DDRB=0;
DDRC=0b11111111;
PORTC=0b00000000;
PORTB=0b00000000;
{PORTC=0b11111111;}
return 0;
von B.A. (Guest)
Rate this post
useful
not useful
>> Ground?
> Yes...Done that
Realy?
PC6 is the Reset-Pin of the ISP-Port ... this Pin must be high, if it is
Low the AVR is in Programming-Mode.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
