EmbDev.net
Forum: µC & Digital Electronics LPC 2129 PWM problem
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Anand B. (Company: Self) (abhavikatti)
Rate this post
useful
not useful
Hi all
I am working on single edge PWM generation on LPC 2129 .The summary o my
work is as below
1)I am able to see PWM output on Pin 33(PWM 4).it is as per my clock
settings.No problem still here.
2)In the PWM ISR,I am setting 2 flags and in the main loop of the code
,and based on these flag values I am dynamically changing PWM4 rate by
changing PWMMR0 ;PWMMR4 PWMLER registers.
3)These above mentioned changes are not reflected in the scope output.I
dont see my modified rate settings on the scope.
Attached is the code.Please help me.
Regards
Anand
Rate this post
useful
not useful
The stuff is working fine. I have to use volatile qualifiers for flags
used in ISR and in  main loop.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
