EmbDev.net
Forum: µC & Digital Electronics AVR ATmega8, cannot transmit multiple characters via UART, data getting lost
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Alex K. (Company: ---) (akap)
Rate this post
useful
not useful
I think I have a very simple problem, but as a beginner I cannot find a
solution.
I am writing a code for a MCU until that will transmit data via UART
(RS232). [ATmega8A]
Currently, I am testing my code in Proteus:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdlib.h>
#include <compat/twi.h>
#define FOSC 16000000     //Clock Speed
#define BAUD 9600         //Baud rate set to 9600
#define MYBRR FOSC/16/BAUD-1
void USART_Init (void)
UBRRH = (MYBRR >> 8);        //Code for setting
UBRRL = MYBRR;               //the baud rate
UCSRB = (1 << RXEN) | (1 << TXEN); //Enable receiver and transmitter
UCSRC = (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1);
//Frame format setting: 8 Data, 2 Stop bit
/* USART transmit function */
void USART_Transmit(unsigned char data)
  while(!(UCSRA & (1 << UDRE)));//Wait until transmit buffer is empty
     UDR = data;
/* USART receive function */
unsigned char USART_Receive(void)
     while(!(UCSRA & (1 << RXC))); //Wait until data is received
     return UDR;   //Get the data from buffer and return it
 int main(void)
[c] {
[c] unsigned char c;
[c]while(1)
    a = USART_Receive();
    c = 10;
    USART_Transmit(c);
    _delay(10000);
n Proteus, the virtual terminal displays 0. However, I am expecting to
see 10. This is just one example, in general only the last
digit/character is getting displayed on the virtual terminal.
Same happens if I want to transmit say AA, only A will be displayed.
I cannot explain this. Proteus bug or logic error?
Thank you for any advise.
von c-hater (Guest)
Rate this post
useful
not useful
What, the f**k is Proteus? For what is it good for?
> (RS232). [ATmega8A]
Stupid, but may work. You should clarify your intention using braces.
#define MYBRR (FOSC/16)/BAUD-1
Much better is it with implicite rounding:
#define MYBRR (FOSC/16+BAUD/2)/BAUD-1
Your code partially doesn't match the provided comment. Matches for
number of data bits, but doesn't match for number of stop bits.
Poor implementation. It doesn't care the possebility of transmission
errors.
> see 10.
You shouldn't. If you send a char with value 10, you will receive a char
with value 10 (in the case there is no transmission error and sender and
receiver uses same frame format).
You can expect to get a visible "10" in the only case, the receiving
terminal replaces received, but unprintable characters with decimal
strings, describing their values.
Probably your error. Either you made a mistake in your code or you don't
understand what "Proteus" does. Whatever "Proteus" is...
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
