EmbDev.net
Forum: µC & Digital Electronics AVR - ATmega8A - External Interrupt - Sometimes odd behaviour
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Alex K. (Company: ---) (akap)
Rate this post
useful
not useful
I am currently working on a MCU unit which will respond to external
interrupts in order to perform specific tasks. The controller I am
using: ATmega8A.
The external interrupt is defined as followed:
PORTD |= 0x04;                //Activate pull up resistor of PD2
GICR |= (1 << INT0);          //Enable INT0
MCUCR |= (1<<ISC00);          //INT0 is executed on every edge
The ISR:
ISR (INT0_vect)
                /* interrupt code here */
                v = 1;          //sets interrupt variable v to 1
The variable v is defined as : volatile int v.
 volatile int v = 0;
I am currently testing the behavior of the external interrupts. Whenever
an external interrupt is detected a particular code block should be
executed. The interrupt is applied to the INT0 by any logic change.
 ISR (INT0_vect)
 int main(void)
    USART_Init();
    I2C_init();
    //int a;                      //test variable
    sei();
    unsigned char a;
    a = USART_Receive();
 while(1)
        //TODO:: Please write your application code
        do
        } while (v == 0);     //Wait for interrupt
        v = 0;
        _delay_ms(10000);
  //Communication protocol between MCU unit and GUI software application
            //Block 1
            USART_Transmit(0xFF);                           //Header start command
            USART_Transmit(0x00);
            USART_Transmit(0x08);
            USART_Transmit(0x09);
            USART_Transmit(0x02);
            USART_Transmit(0x04);
            USART_Transmit(0x05);
            USART_Transmit(0x06);
            USART_Transmit(0xFE);                           //Header finish command
            do
            v = 0;
        _delay_ms(10000);
 //Block 2
            USART_Transmit(0x01);
     return 0;
[c]
Testing the code, I can say that the interrupts are recognized and the
code is functioning. However, it seems that there is a little bug or
logic error. When the first interrupt occurs (before block 1), block 1
is supposed to be executed. Now, if the second interrupt occurs, the 2nd
block should be executed.
I can see this execution sequence in a pre-written GUI application,
however, most of the time block 1 (when applying the interrupt) is
executed many times after another and than block 2.
It should always be the following sequence: block 1 than block 2 and so
on. I think that this is a timing issue. But I cannot debug this
problem.
I am also wondering if there is a code in C that tells the program to
wait for an external interrupt signal and than continues the program?
Thank you very much in advance.
von Marc Vesely (Guest)
Rate this post
useful
not useful
> problem.
Is this now your complete code ( Except diverse #include etc.) ?
ISR (INT0_vect)
 volatile int v = 0;
 int main(void)
    USART_Init();
    I2C_init();
    sei();
    unsigned char a;
 while(1)
        do
23
        { } while (v == 0);     //Wait for interrupt
24
        v = 0;
25
        _delay_ms(10000);
26
27
  //Block 1
28
29
30
31
32
33
34
35
36
37
38
39
40
        do
41
42
        v = 0;
43
        _delay_ms(10000);
44
 //Block 2
45
46
47
48
49
50
51
52
53
54
55
56
57
58
     return 0;
59
 If so, pls. post as such and not as bedsheet with unnecessary
 empty lines.
 Do you have TxBuffer ?
von Martin (Guest)
Rate this post
useful
not useful
Try to use this instead of the _delay_ms(10000):
for (uint16_t i=0; i<=10000) _delay_ms(1);
The maximal possible delay is 262.14 ms / F_CPU in MHz.
When the user request delay which exceed the maximum possible one,
_delay_ms() provides a decreased resolution functionality. In this mode
_delay_ms() will work with a resolution of 1/10 ms, providing delays up
to 6.5535 seconds (independent from CPU frequency). The user will not be
informed about decreased resolution.
von Martin (Guest)
Rate this post
useful
not useful
for (uint16_t i=0; i<=10000; i++) _delay_ms(1);
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
