EmbDev.net
Forum: ARM programming with GCC/GNU tools Samsung S5P4418 development board
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Steffie C. (Company: Shenzhen Graperain Technology) (graperain)
Rate this post
useful
not useful
Customized Arm Solution Embedded S5P4418 Development Board Linux
CPU processor
Samsung S5P4418, Cortex-A9 Quad-Core, 1.4GHz
Memory
RAM: 1GB DDR3 RAM, 32bit data bus (Support expand 2GB DDR3 RAM)
Flash: 8GB eMMC Flash(Optional 8GB/16GB eMMC Flash)
On Board resource
Audio Chips: Use Audio chips on board, Audio In/Out
Power IC: Using power IC
Expand interface
TFT LCD : Support RGB TFT LCD output, upto 1920*1080
LVDS: Support LVDS LCD output, upto 1920*1080
HDMI: HD Video/Audio output interface, HDMI1.4a
Camera: One Camera interface
Touch: Support Capacitive touch screen
Etherent: Support Gigabit Ethernet expand
USB Host: One USB HOST 2.0, One USB HSIC
USB OTG: One OTG 2.0
UART: Support six UART interface, support RTS/CTS serial port
Audio: One MIC, One Speaker, support earphone
SD Card: Two SDIO interface, One for SDIO WiFi, One for SD card
RTC Backup: Support RTC battle input
PWM/IIC/SPI/ADC: Two PWM, Three IIC, two SPI, Two ADC, One PCM, One PDM
GPIO: Upto 53 GPIO with interrupt
Structure parameters
8 layer, 60 x 40 x 2.5(mm)
188Pin QFP expand interface
Electrical Characteristics
Power in: Supply Voltage 5V, Support Li-battle
Power out: 3.3V(power for base board or charge the Li-battle)
Two Alive GPIO
Work Temperature range: -10 to 70 °C
S5P4418 Development Board Linux expand the follow function:
UART: Two RS232 Serial port in DB9 interface, Two TTL Serial in 4Pin
Header
RS485: One RS485 interface
CAN Bus: One CAN Bus, Support CAN 2.0B
USB: Two USB Host and one USB OTG
Audio: One MIC on board, One Speaker interface and one earphone
interface
HDMI: One HDMI interface, 1.4a HDMI
LCD: One TFT LCD interface with Capacitive touchscreen
LVDS: One 2.0mm pitch 2*10P Standard LVDS interface
Ethernet: One Ethernet interface
Camera interface: Support CMOS Camera and AV In Camera
IIC interface: One Standard I2C interface, 2.0mm pitch 4Pin Header
GPIO interface: Two GPIO, 2.0mm pitch 4Pin header
SD card: Standard TF card slot
Sensor: Support Acceleration of gravity
Key: Audio +, Audio -, Reset button, Power up/down key
Expand Module Support:
WiFi module: Use SDIO intreface
Bluetooth Module: User Uart interface
GPS Module: Support GPS module
Camera Module: Support 500M CMOS camera
AV Camera Module: Support AV In Camera
3G/4G modem: Standard Minipci-E interface
Li-Battle: provide LI-Battle box, support 3.7V Li-Battle
LED: System status LED, Charge status LED
Libattle charge: 2A
RTC back up battle
Sleep and wakeup
5V Power in interface
von Shenzhen Rapetrain Technology (Guest)
Rate this post
useful
not useful
WoooWooooooo!
von Sachin (Guest)
Rate this post
useful
not useful
I want Samsung S5P4418 development board
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
