EmbDev.net
Forum: µC & Digital Electronics Gamebuino based on arduino nano
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von David R. (retrogadgets)
Rate this post
useful
not useful
Based on the Gamebuino at www.gamebuino.com
My implentation using an arduino nano dev board
The boot loader has been flashed eith a modified version of optiboot.
Shall post further developments as I test the board
Next shall be the micro sd reader
: Moved by Moderator
Rate this post
useful
not useful
Rate this post
useful
not useful
At the moment my layout based on this schematic
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
I can see no (in numbers 0) decoupling capacitors at the ATmega...
You should NOT conntect Aref to Avcc. Instead you sould connect only a
capacitor from Aref to GND:
      Vcc --------| Avcc
           .------| Aref
10n..100n ===
Then you can also make use of the internal reference volatage. And of
course you can use Vcc as refeerence voltage also. Simply select it as
reference source in the ADC settings.
: Edited by Moderator
Rate this post
useful
not useful
Lothar I'm only using the schematic as a guide, I dont have any
connection to aref at the moment.
But I'll bear it in mind for later
Rate this post
useful
not useful
Ive now rewired the board, it looks alot better
The sd board is attached, formatted to fat 16, loader.hex and
settings.hex are present on the sd card.
With the sd card is inserted, the screen backlight has a slight pulsing
action, take it out and its steady! Both the screen and the sd module
connect to the same clock and mosi.
The sd card is running off 5v via its on board regulator and the screen
off 3.3v from the nano
Next for the buttons
Rate this post
useful
not useful
Using the arduino ide and editing the board.txt file
Place this code at the end
gamebuino.name=Gamebuino Nano
gamebuino.upload.tool=avrdude
gamebuino.upload.protocol=arduino
gamebuino.bootloader.tool=avrdude
gamebuino.bootloader.unlock_bits=0x3F
gamebuino.bootloader.lock_bits=0x0F
gamebuino.upload.maximum_size=30720
gamebuino.upload.maximum_data_size=2048
gamebuino.upload.speed=57600
gamebuino.bootloader.low_fuses=0xFF
gamebuino.bootloader.high_fuses=0xDA
gamebuino.bootloader.extended_fuses=0x05
gamebuino.bootloader.file=gamebuino_boot/gamebuino_boot.hex
gamebuino.build.mcu=atmega328p
gamebuino.build.f_cpu=16000000L
gamebuino.build.board=AVR_NANO
gamebuino.build.core=arduino
gamebuino.build.variant=eightanaloginputs
Then using a usbasp programmer, connect the icsp header to the nano
board.
Then goto tools in the ide and select programmer as arduino asp or
usbasp, choose board as gamebuino nano then choose burn bootloader
Hey presto the bootloader is written and when the sd module is wired
pressing c on the clone the bootloader flashes the Gamebuino clone with
the loader.hex for choose what ever is on you sd card, game or settings.
Rate this post
useful
not useful
Prior to doing the above
Download and extract to my documents on windows or the sketch folder if
on mac the 3 folders
When using the arduino ide, goto examples to see if gamebuino is there,
if so you have installed the routines for the Gamebuino clone
https://github.com/Rodot/Gamebuino/archive/master.zip
Rate this post
useful
not useful
My new layout using single core hook up wire
The left button A , the middle button is down, the right button is C for
exiting games and accessing the SD
Next a nice pcb with probably just a atmega 328 instead of the nano
board
von Pete K. (pete77)
Rate this post
useful
not useful
What is your problemuino?
Rate this post
useful
not useful
I have no problem, I am the author and  this is my post
If anyone else would like to build
von Rishabh (Guest)
Rate this post
useful
not useful
In my homemade gamebuino,I have problem with sd card(2gb) ,when I insert
this card on gamebuino and it start pulsating screen, just like
continuously blinking screen, please help me.
Rate this post
useful
not useful
Hi. You need a 100nf decoupling capacitor on the supply lines to the
lcd.
Rate this post
useful
not useful
My latest design. Fully compatible with gamebuino and makerbuino.
von Woz is in the air (Guest)
Rate this post
useful
not useful
There  is no layout, this is a mess! Get yourself a soldering iron if
you wish to become an engineer.
von Bastler (Guest)
Rate this post
useful
not useful
THT components ... really?!
Groundplane?
von Felix F. (wiesel8)
Rate this post
useful
not useful
> Groundplane?
Well, i don't see any sense in recreating something that already exists
except learning purpose.
But whats the problem with THT? It's easy to solder and absolutely OK
for home made projects like this.
And theres no need for a ground plane on "slow" mcu's like AVRs, but it
would be good for learning how to make perfect layouts.
mfg
Rate this post
useful
not useful
Why don't You all stop bitching. If you don't like it, don't comment
with shit criticism. This is a diy version of a smd board for noobs to
make.
See my website at www.makerbuino.com
von chris calonzo (Guest)
Rate this post
useful
not useful
I also made a diy gamebuino.
bootloader from rodot's file going to arduino uno.
same schematics.
but sd card doesn't flash after pressing C button.
LEFT button is pressed already, i removed the LEFT button wiring &
ground but at the SETTINGS, LEFT cursor is enable already.
I uploaded the LOADER.ino in the arduino uno & my sd card is read, still
my LEFT cursor is a problem.
Do I missing something?
Rate this post
useful
not useful
same schematics.
von David (Guest)
Rate this post
useful
not useful
Believe you need pin 4 if digital pin on arduino uno dev board for left
von Jaisegyi J. (jaisegyi)
Rate this post
useful
not useful
von MaWin (Guest)
Rate this post
useful
not useful
Maybe, you don't understanduino it?
von DreamRunner (dream_runner)
Rate this post
useful
not useful
Thank you for your great project !!!
Unfortunatly, the Drive link to the bootloader seems broken.
Could you give me a copy of it, please ?
Regards.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
