EmbDev.net
Forum: PCB Design & Technology Six Key Strategies To Make PCB Work Smarter
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Jenny G. (Company: Kinji) (jenny_pcb)
Rate this post
useful
not useful
I. Collaborative Product Development Process
Generally, collaborative refers to the ability of changing serial
operation into parallel operation, and it has two modes. First model is
let multiple designers to work simultaneously on the same design flow.
It's not new in market, but it has big difference on efficacy compared
before. Designers are always able to operate PCB design database and
split, and every designer is working in design process. But the database
must be re-combined, though it's very time-consuming and error occurs
easily, it can shorten the design cycle at the end!
Currently, we have the ability to let multiple designers work
simultaneously in the same database, without having to split the
database. It can be used for many PCB design process, such as schematics
inputs, constraining inputs, management and physical layout. Besides,
let designer see the real-time result of others. It not only
significantly reduces the design cycle time, but also improve the
productivity of the designers and quality of products. Some users'
reports show that the technology saves 30 to 70% of the design time.
Companies ought to get the similar improvement to keep competitive.
The second model is the ability to run several different processes, and
it's a parallel pattern which is different form sequences. Schematics,
constraints, and layout analysis can be parallelized, thereby improving
designer productivity better and shorten design cycles. However, this
mode requires complex design data management which contains version
management, synchronization, calibration, permissions, this will be
explained later in this article.
: Moved by Moderator
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
