EmbDev.net
Forum: µC & Digital Electronics STM32F303 Discovery: SPI basics
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Harald (Guest)
Rate this post
useful
not useful
I try my first programming on an STM32 Discovery Board (STM32F303). I
was using avrs before for years :-)
First step should be to get the SPI to work. My IDE is Eclipse with gnu
arm eclipse-plugin.
All I want to see for now is the working SPI on an oscilloscope.
But the following code shows nothing at CLK or MOSI:
int main(int argc, char* argv[])
  BlinkLed blinkLed;
  GPIO_InitTypeDef GPIO_InitStructure;
  SPI_InitTypeDef SPI_InitStructure;
  blinkLed.powerUp();
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  // PB13 = SCK; PB15 =  MOSI
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_13 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_6);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_6);
  // Chip select pin
23
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8;
24
  GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_OUT;
25
26
27
28
29
  GPIO_SetBits(GPIOB, GPIO_Pin_8);
30
31
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
32
  SPI_InitStructure.SPI_CPHA       = SPI_CPHA_2Edge;
33
  SPI_InitStructure.SPI_CPOL       = SPI_CPOL_High;
34
  SPI_InitStructure.SPI_CRCPolynomial     = 1;
35
  SPI_InitStructure.SPI_DataSize     = SPI_DataSize_8b;
36
  SPI_InitStructure.SPI_Direction     = SPI_Direction_1Line_Tx;
37
  SPI_InitStructure.SPI_FirstBit     = SPI_FirstBit_MSB;
38
  SPI_InitStructure.SPI_Mode       = SPI_Mode_Master;
39
  SPI_InitStructure.SPI_NSS       = SPI_NSS_Soft;
40
  SPI_Init(SPI2, &SPI_InitStructure);
41
42
  SPI_Cmd(SPI2, ENABLE);
43
44
  uint8_t i = 0;
45
46
  while (1)
47
48
      i++;
49
50
      blinkLed.turnOff();
51
      SPI_SendData8(SPI2, i);
52
53
      while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET)
54
55
56
      blinkLed.turnOn();
57
58
Is there any bus or clock I didn't switch on?
Trouble with the TX-FiFos? Must I use the TX-Interrupt?
I inspected the code with the debugger - it cycles correctly through the
while-loop...
Any help would be appreciated. Thank you.
von Harald G. (andobrawan)
Rate this post
useful
not useful
Wrong alternate port-function!!!!
Changed it to GPIO_AF_5 and it works.
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_5);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_5);
Further on I had to add a line in the GPIO_InitStructure:
GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
