EmbDev.net
Forum: µC & Digital Electronics STM32F407 SPI reads wrong data
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Mirko (Guest)
Rate this post
useful
not useful
Hey,
I'm encountering a strange problem with the hardware SPI of the
STM32F407 [2] (discovery board). I'm trying to communicate with an UM7
IMU [1] over its SPI interface.
When I try to read its firmware revision, I receive ASCII 'T71E' instead
of the expected 'U71D'. You can see the SPI transmission recorded using
a logic analyzer in the pictures, with the closeup showing the
transmission for the last byte, which should be 'D' but is 'E'.
To me at least it looks like the data is transmitted correctly by the
UM7, but somehow the STM reads the last bit incorrectly.
The behavior is reproducible, i.e. the first and last byte always have
the last bit flipped.
Are there any pitfalls for the STM SPI I should aware of? Or am I doing
something else wrong?
Regards,
Mirko
[1] Datasheet UM7: https://www.chrobotics.com/docs/UM7_Datasheet.pdf
[2] Datasheet STM32F407:
http://www2.st.com/content/ccc/resource/technical/document/reference_manual/3d/6d/5a/66/b4/99/40/d4/DM00031020.pdf/files/DM00031020.pdf/jcr:content/translations/en.DM00031020.pdf
Code, in case I just made a dumb error somewhere...
void spi_init(void) {
      hspi.Instance = SPI1;
      hspi.Init.Mode = SPI_MODE_MASTER;
      hspi.Init.Direction = SPI_DIRECTION_2LINES;
      hspi.Init.DataSize = SPI_DATASIZE_8BIT;
      hspi.Init.CLKPolarity = SPI_POLARITY_LOW;
      hspi.Init.CLKPhase = SPI_PHASE_1EDGE;
      hspi.Init.NSS = SPI_NSS_SOFT;
      hspi.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
      hspi.Init.FirstBit = SPI_FIRSTBIT_MSB;
      hspi.Init.TIMode = SPI_TIMODE_DISABLE;
      hspi.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
      hspi.Init.CRCPolynomial = 10;
      HAL_SPI_Init(&hspi);
uint8_t transceive_byte(uint8_t data) {
    uint8_t recv = 0x00;
    HAL_SPI_TransmitReceive(&hspi, &data, &recv, 1, HAL_MAX_DELAY);
    return recv;
uint32_t transceive_packet(uint8_t mode, uint8_t addr, uint8_t* data) {
24
25
    HAL_GPIO_WritePin(GPIO_IMU_SS_GPIO_Port, GPIO_IMU_SS_Pin, GPIO_PIN_RESET);
26
    delay(10); // delay is in uS
27
    transceive_byte(mode);
28
    delay(20);
29
    transceive_byte(addr);
30
31
    uint32_t recv_data = 0;
32
    for(int i = 0; i < 4; i++) {
33
        delay(20);
34
        recv_data |= transceive_byte(data[i]) << (i * 8);
35
36
37
    HAL_GPIO_WritePin(GPIO_IMU_SS_GPIO_Port, GPIO_IMU_SS_Pin, GPIO_PIN_SET);
38
39
    return recv_data;
40
41
42
void imu_spi_test() {
43
    delay_init();
44
    spi_init();
45
46
    uint32_t cmd = 0;
47
    char fw_version[5] = {0};
48
    *((uint32_t*)fw_version)= transceive_packet(CMD_WRITE, 0xAA, &cmd);
49
50
    trace("FW: %s\n", fw_version);
51
von Mirko (Guest)
Rate this post
useful
not useful
Nevermind, using SPI2 works fine. I think the jtag interface shared some
pins with SPI1, which caused the errors.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
