EmbDev.net
Forum: PCB Design & Technology Compariation of TVM 802A & CHMT 36V
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von RobotDiggMe (Guest)
Rate this post
useful
not useful
RDGTVM802A SMD Machine
360° Rotating Head Support
Hardware Properties
Version
RDG 802A
Applicable PCB
20mm*20mm--330mm*340mm
XY moving range
425*500mm
Z moving range
15mm
Mounting capability
5500 component per hour
Mounting accuracy
0.025mm
Applicable components
0402,0606,0805,sop8 ...QFN
Components supply configuration
Tape real,bulk package(IC)
Tape width, feed combinations
8mm,12mm,16mm(8mm=22  12mm=3  16mm=1 ic=1)
feeders
26
Machine dimension
875mm*640mm*310mm
Visual camera
2 HD CCD Camera
Visual system(down)
Automatic recognize fiducial mark
Visual system(up)
Automatic recognize components and adjust
Vacuum pump quality
3 cacuum pump (one positive,two negative)
Power supply
AC220V or AC110V
power
150W
weight
G.W:60kg   N.G:50kg, Vaccum W.:76kg
Packing size
0.4
The boundary dimension of this equipment is 875mm*640mm*310mm It mainly
consists of a work head, top and bottom visual systems, a work table,
feeding racks, etc.The moving range of X and Y axes is 395*445mm, while
the moving range of Z axes is 15mm.,PCB of size 330*340mm at most,
available for jointed board operation.
CHMT 36
PCB Area
10mm*10mm~380mm*415mm
XY axis travle
420×460mm
Z axis moving range
15mm
Nozzle quantity
2pcs
Stake feeders
37 Fedders (8MM=22 fedders, 12MM=4 fedders, 16MM=2 fedders, 24MM=1
fedder, prey IC tray  = 8 fedders)
Speed
6000cph(highest 7200cph)
Precision
±0.025mm
Size
0402-5050,SOP,QFN(width:8MM,12MM,16MM)
Dimension
L 960mm×W 705mm×H 335mm
vacuum air pump
-92KPA( in-built ) mute type pump)
air pump
2pcs ( in-built ) mute type pump
voltage
220V(110V), 50Hz
Power
200W
Weight
70kg
Package volume
0.51 m³
Rate this post
useful
not useful
PNP related questions, can email me at asliu@robotdigg.com for quick
answer.
Skype:RobotDogg
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
