EmbDev.net
Forum: µC & Digital Electronics RaspberryPi 3 with NFC for scanning mobile phone
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Ephaltes (Guest)
Rate this post
useful
not useful
Hello Guys,
Wanted to know if it is possible to use the RaspberryPi with its
included WLan to connect to a mysql database, I mean you can code the
Raspberry with C++ so i think that should be possible to create a
connection to a mysql (asking because not tested yet)
So now to my real problem.
I wanted to use a NFC Reader to read an NFC Tag/Card and Phone
so far i used the RC522 and the NXP PN532 from Elechouse the problem now
is both could find a tag/card but both couldnt find a Phone that used
NFC (Samsung S5).
So I wanted to know if it´s even possible to read from a phone.
What i wanted to do is read the nfc number from a phone/tag/card then
save it to a database and the next time the same number appears it shows
something like already in database.
So i think the problem here is just the NFC part, because the Raspberry
Pi supports Phyton C/C++ so the database thing shouldnt be a problem
Regards
von Mick (Guest)
Rate this post
useful
not useful
Doing mySQL stuff over network is fairly easy. You will find lots of
sample code online.
If you're using the PN532, reading the phone's ID should be working. Try
this library https://github.com/Seeed-Shield/NFC_Shield_DEV
RC522 is Mifare RFID only! Your phone can't communicate with it.
von Darkos M. (Company: estovia) (abigail)
Rate this post
useful
not useful
Hello, as we are discussing the NFC for scanning mobile phone are used
to bypass the firewall and allow you to access media resources that are
normally blocked. The best thing about these features is that many
times, they will work even when your app isn't open. This can be
especially cool if you want to make sure nobody else is using a family
member's device. https://veepn.com/vpn-apps/vpn-for-ios/ use with proxy
servers to prevent the web traffic from being intercepted and the
surfer's identity being revealed to an 3rd party. It is a great way to
bypass the government censorship but this device.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
