EmbDev.net
Forum: PCB Design & Technology Moving a selected group in EAGLE
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Marcus (Guest)
Rate this post
useful
not useful
Hello,
I have an incomplete Layout in a limited version of EAGLE. I already use
up all of the available space, so moving the Board boudaries is not an
option.
Due to a misjudgement of space I need to move a selectable group of
carefully aligned parts (mount holes for a display, buttons, display).
Is there a way to tell Eagle to move the entire group, lets say 10mm to
the left? I dont want them to move up or down, as could accidentally
happen when I use my mouse. I have seen something like this in other CAD
Software, where you could use the arrow-keys and type in the distance.
von Falk (Guest)
Rate this post
useful
not useful
Simply GROUP your components, then set the grid to 10mm, finally MOVE
the group. Since the grid is set to 10mm, its fairly easy.
von Falk (Guest)
Rate this post
useful
not useful
You can also use the command line for this.
GROUP the components using the mouse, then type in the command line
move (> 0 0)
This will select the group in the origin 0 0
(10 0)
This will drop the group at the coordinates 10 0
This way you can move a group easy and precicely by any offset.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
