EmbDev.net
Forum: PCB Design & Technology Judgment of PCB circuit board good or bad way:
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Cici Y. (sun_h)
Rate this post
useful
not useful
First: from the appearance of the circuit board to distinguish between
good and bad
Under normal circumstances, PCB circuit board appearance can be judged
by three aspects;
1, the size and thickness of the standard rules.
The thickness of the circuit board to the standard circuit board is
different depending on the size of the product and can be measured
according to the thickness and specifications of the product.
2, light and color.
External circuit boards are covered with ink, the circuit board can play
the role of insulation, if the color of the board is not bright, less
ink, insulation board itself is not good.
3, the appearance of the weld.
Circuit board due to more parts, if the welding is not good, parts easy
to fall off the circuit board, seriously affect the quality of the
circuit board welding, the appearance of good, carefully identified, the
interface is very important point is very important.
Second: high-quality PCB circuit board needs to meet the following
requirements
1, requiring components installed after the phone to be easy to use,
that is, to meet the requirements of electrical connections;
2, the line width, line thickness, line spacing meet the requirements,
so as to avoid the line heat, open circuit, and short circuit;
3, by the high temperature copper is not easy to fall off;
4, copper surface is not easy to oxidation, affecting the installation
speed, after oxidation soon after the bad;
5, no additional electromagnetic radiation;
6, the shape is not deformed, so as not to install after the shell
deformation, screw hole dislocation. Are now mechanized installation,
circuit board holes and lines and design of the deformation error should
be within the allowable range;
7, and high temperature, high humidity and resistance to special
circumstances should also be considered within the scope;
8, the surface of the mechanical properties to meet the installation
requirements.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
